Final drive breakdown - repair or replace help
wildhair523
Re: Final drive breakdown - repair or replace help
Post by wildhair523 » Fri Jul 12, 2019 12:20 pm
Got it - thanks.
Born OK the First Time!
"Do not go wherever the path leads. Instead, go where there is no path and leave a trail " Emerson
2000 Yamaha RSV
2013 Ural T - "Trece Suerte" - Lucky 13
wildhair523
Post by wildhair523 » Sat Jul 27, 2019 5:59 pm
Final follow-up - new final drive installed, no problems. I got the driveshaft lined up the best I could with the U-joint yoke. Everything greased & added the 3.5 oz. 80-90 wt gear oil to the FD.
I also put on a new tire & tube (hadn't done that before), adjusted rear brakes, checked & adjusted tappets & torqued the head bolts. While it was immobile - I also cleaned the air filter & adjusted clutch lever free play, oil & trans oil checked.
I sent the damaged FD to Terry Crawford for rebuilding. I think I'm done. That's more mechanic work than I've done in may years.
2000 Yamaha RSV
n3303j
Post by n3303j » Wed Jul 31, 2019 10:22 am
Can't believe the threads in the ring gear stripped out. That gear should be hardened.
wildhair523
Post by wildhair523 » Wed Jul 31, 2019 12:37 pm
Yeah - it surprised me when I split the case & looked inside. I finally got a chance to road test her today - feels smoother & tighter when shifting and accelerating. Running very nice. Brake adjustment seems good as well. Now to figure out some time when I can complete my quest.
2000 Yamaha RSV
