What? How? Why? This just cracked open on me.
Soccerball
Post by Soccerball » Fri Jun 14, 2019 10:03 am
I do not know what happened. I was driving about 45 - 50 and just shifted up into 4th and I felt the bike move in a manner I would expect if my tire suddenly went flat and it was a bit frightening when the bike suddenly moved like a snake glides with the tail moving left to right.
I pulled over and was looking at this. 2017 gear UP I am under warranty 18 months owned, bought brand new, only about 2,000 miles as driving is impacted by weather in IOWA.
The part I call it as the 'Shaft Drive'. View is from top.
Is there anything in my driving and shifting that could have caused this? I just cannot figure that idea out in my head what I might do that would cause this.
I think it mighty be maybe a defective part?
Could it have been a problem in assembly of the gears? The shifting was always rough and clunked, but I was told by the selling dealership and also when I brought in in for maintenance on the maintenance schedule it was how the bikes were and it was normal.
Re: What? How? Why? This just cracked open on me.
Post by Peter Pan » Fri Jun 14, 2019 10:32 am
Well, now I am not alone anymore. In my case it was caused by the nut that connects handlebar with seat.
Post by gobium » Fri Jun 14, 2019 10:41 am
Your final drive was loose.
The 4 nuts not tight down or check during breaking period.
Soccerball
Post by Soccerball » Fri Jun 14, 2019 10:54 am
Covered by 2 year warranty? I did bring it to ural shop per maintenance schedule.
vetsurginc
Post by vetsurginc » Fri Jun 14, 2019 11:58 am
I've a 2011 GU that started loosening the studs of the FD. Even with Red Loctite two just wouldn't stay put. Safety wired the nuts on the studs, and problem solved; nuts hold the studs. Still check every time I ride.
Doug
2010 R1200RT Gustav
Post by rougaroo » Fri Jun 14, 2019 1:14 pm
Search for thread by Tomcatfixer on loose FD mounting bolts. There are a number of fixes, all discussed in that thread. Basically the holes in the FD are too large for the bolts that go through them. Unless you put bushings of some sort in the holes or around the bolts, the constant torque will whack at the case and cause cracks first and then failure.
Should be covered under warranty, but worth the fix as insurance against it happening again.
(I'm being an a$$hole and not just providing the thread 'cause we've had a lot of folks join recently who haven't learned how to use the search function. Not trying to be unfriendly, but for an incredible number of things there are already solutions on the forum if you just look for them. Teach a man how to fish...learn how to search.)
AndyH
Post by AndyH » Fri Jun 14, 2019 5:40 pm
Deleted -
Didn't realize the GU was a 4 bolted 2WD - we don't have them where I come from.
Check your nuts, men - often and early :)
2015 Ural EU Tourist -
Post by Lokiboy » Fri Jun 14, 2019 7:06 pm
Just to clarify, the OP has a GU. Tomcatfixer’s issue was with the two bolt play of a 1WD. Gobium stated correctly, you need to make sure the bolts are tight on both models. Learn to do the maintenance yourself. Know your rig and you’ll learn overtime what’s normal and when it’s not.
mattzahr
Post by mattzahr » Fri Jun 14, 2019 8:36 pm
At one time Gobium offered some special order nuts that would "bite" and help resolve this as well.
What Lokiboy said is a ground truth - know your ride and it will pay off. Hope you have an easy fix....
'16 cT - Terracotta 20k and climbing
Former bikes
2005 HD Springer Classic
1983 R80RT
Subsnowden
Post by Subsnowden » Fri Jun 14, 2019 9:49 pm
I ate my first FD within 2500 kms. Welcome to the club lol
Jon
Nomad
2015 Ural Gear Up
Fredrikrosen
Post by Fredrikrosen » Fri Jul 05, 2019 3:11 pm
I have the impression 2WD FD’s are way more fagile than the 1WD even if not used in 2WD so much.
Ural 750 Retro -2010
Ural Voyage 720 -1999
Ural 650 Solo Export -1992 :sold
IZH Jupiter-3 -1980
IZH Planeta-5 -1992
Honda CR500R -1984
Dnepr MT16 with BMW engine :sold
Dnepr K650 -1969 :sold
Ural 650 -1993 :sold
Plus another 50+ bikes though the years.
Post by Mr Wazzock » Fri Jul 05, 2019 8:01 pm
I like to check the tightness of my FD nuts every 200 - 300 miles, roughly. (Not found a loose one yet.) Usually part of a general check of "critical fasteners" for tightness.
africalight
Post by africalight » Fri Jul 05, 2019 10:05 pm
Where you at in Iowa? I’m in Davenport area.
2006 Patrol-Totally Rebuilt Engine and going through break in again
Post by GHGoodwin » Sat Jul 06, 2019 5:49 am
Same here. Got tired of rehashing.
Grumpy time over. Time to grab a linguisa roll and catch the ferry to the mainland. Homeward bound.
