Make Your Own Racks!
Maineiac
Post by Maineiac » Sun Dec 08, 2019 3:13 pm
Make your own racks! Your imagination is the only limiting factor. You will need to know how to weld.
Things you need:
-3/4 steel tube from Home Depot. The thickest they sell.
-2 molding pieces like the ones pictured. You’d do a wonderful job if you routered two constant radius pieces with the exact profile of you tubing. I’m a for s*%# woodworker.
-Patience
-beer
-welder
Take the sections of tubing that you have and place one end in between the two fixed pieces and bend them. Try to keep them parallel to you work surface. I’m sure someone can do an even better job than I did, using patience and skill.
‘96 Ural Tourist w/an R100 motor.
1150GS w/a Ural sidecar.
Maineiac
Re: Make Your Own Racks!
Post by Maineiac » Sun Dec 08, 2019 3:19 pm
Finished product. I’d say that I knocked off most of these rack ideas from Claude Stanley and DMC, so feel free to copy them.
lendrinkard
Post by lendrinkard » Sun Dec 08, 2019 4:50 pm
Nice :)
2012 Gear up - 130/40 jet, 3 shims, no mid-pipe, drilled slider, 2013 Branch pipes, all LED lights
2013 NOS Ural T - 130/42 jet, 2 shims, LED running lights, oil cooler
Post by Lmo » Sun Dec 08, 2019 5:06 pm
N-I-C-E! You're getting some nice bends out of that little set up; I would have expected the inside radii would have collapsed a bit.
That's why I went with square tube; looking crude by comparison.
I'm liking that 'flat' fender too. When did you find it?
Post by Tomcatfixer » Sun Dec 08, 2019 5:47 pm
Outstanding work!
I hope I didn't exceed my authority here, but I rotated your sideways images to the proper orientation so that your viewers can better enjoy your handiwork.
Post by Pterodactyl » Sun Dec 08, 2019 8:02 pm
Hell, I could do that once I have the skills, knowledge, aptitude, talent, tools, resources and energy. Until then all I have is admiration. Well done!
Post by Snakeoil » Sun Dec 08, 2019 9:38 pm
You just need to rack your brain. :boogie:
Maineiac
Post by Maineiac » Mon Dec 09, 2019 3:26 am
I experimented with a bunch of different materials and methods; sand in the tube, heat, etc. I tried to bend up larger than 3/4” with sand and heat, but I couldn’t get consistent results.
The fender is a Ural speed shop item; tractor supply.
Maineiac
Post by Maineiac » Mon Dec 09, 2019 3:28 am
Outstanding work!
I still don’t know why they post sideways?!?! Thanks so much.
Post by siberman1 » Mon Dec 09, 2019 6:02 pm
Saaaaay There!
What kind of wheel is on the sidecar? Curious.
Post by Lmo » Mon Dec 09, 2019 10:50 pm
A 15" something that fits on a DMC sidecar ... :P
Maineiac
Post by Maineiac » Wed Dec 11, 2019 3:31 am
Saaaaay There!
It’s off a bmw 1150xx and it’s 17”. This sidecar was mounted to my 1150GS. My Ural is used mainly for winter riding now. I went with the 17” wheels all around to be able to run a car tire on the pusher and s/c, as well as run a tire up front with a larger contact patch.
Post by VWK75S » Wed Dec 11, 2019 5:45 am
Well done :cheers:
2009 GearUp 150,000kms
Post by stagewex » Wed Dec 11, 2019 10:56 am
Beautiful work. Did you make that Hack Fender too?
You would have customers here if you went into small production runs. Really nice and different from stock and others.
Maineiac
Post by Maineiac » Thu Dec 12, 2019 3:08 am
Hack fender is a 9” trailer fender from tractor supply...like $60. I think they sell a 7” fender as well, which would be suitable for a stock Ural.
