Stuff That Works
Re: Stuff That Works
Post by Speedbump » Sun Jul 14, 2019 12:20 pm
Glenn³
Post by Lofty » Sun Sep 15, 2019 5:29 pm
Pig Spit. An aerosol restorative that removed (at the very least, camouflaged) the annoyingly obvious fuel streaking on the rig's Satin Burgundy paint finish. Nothing else worked, at all, so I'm pleased to offer my unqualified recommendation here for owners with similar factory paint applications.
The flammability warning on the can of spit has some of the strongest wording I've seen in recent memory. This reconciles with my long-held belief that if it's dangerous, it'll likely work as advertised. :)
In my defense, said streaking was caused when residual fuel in a blender pump's hose wasn't retained by a nozzle with a [likely] failed seal. The fuel spilled on to the GU's fuel tank, despite my usual careful handling of the nozzle. Thus the need to attend to the resultant aesthetic damage.
Post by Pterodactyl » Sun Sep 15, 2019 10:39 pm
I love the stuff. I’ve been using it for 6-7 years and none of the explosive burns have hurt too bad. 8)
Post by windmill » Sun Sep 29, 2019 8:42 pm
S 100 Engine Brightener also works very well, and may last a bit longer.
Post by Lofty » Thu Oct 10, 2019 11:09 am
Sheila Shine. A polish intended for stainless steel. An obvious off-label use when applied on motorcycle hardware, but this product works remarkably well. Just a bit of spray on a paper towel instantly removes any imperfections on the finish of my Kitchen Aid dual oven range. Just as well that a little goes a long way, as even a small can is a bit pricey.
Post by Lmo » Thu Oct 10, 2019 12:02 pm
Ooooo oo ... . and it comes in gallons ($69.95) !!!
Post by Lofty » Thu Oct 10, 2019 12:25 pm
Shop a little more sharply, Lew, and you'll save a few $$. :D
$35.96/gal.
https://smile.amazon.com/Sheila-Shine-S ... 34&sr=8-21
Post by Msblu79 » Thu Oct 10, 2019 12:40 pm
Off topic comment, I cracked up at Lofty's avatar, reminds me of my idiot boss. :lol: Great product reviews guys, keep'em coming.
2010 Black Patrol 92,000km's
Modtop airbox, 2013 branch pipes, Perch rings, Yamaha petcock, Drilled slides, Gossie needles, 145 mains, 45 pilots, insulated manifolds, Modtop pushrods, Dual FMF exhaust, PA Multi-spark system w/ VOES, Spin on filter conversion, 33mpg, Royal Purple fluids.
Post by Lmo » Thu Oct 10, 2019 5:21 pm
$35.96/gal.
Twue. But I'd hafta buy four of 'em to get that price: $143.83/case.
Post by tgtrotter » Thu Oct 17, 2019 12:36 pm
It caught my interest. Listed as consisting acetone. Works on wood, leather, porcelin ....
$33.21 Delivered
NOT AVAILABLE IN CALIFORNIA !....well kinda not true. There is the low VOC ( Volatile Organic Compound or better yet whatever CA decides to be the active ingredient, is reduced )
Post by harryball » Thu Nov 21, 2019 10:29 am
Pig spit, S100. Both contain silicone? Correct? That will destroy O2 sensors, all it takes is the fumes or aerosolized mist. Take care not to crank the engine while it is still in the air, in fact, close off the tail pipes when spraying it.
Kaliram
Post by Kaliram » Thu Nov 21, 2019 12:28 pm
Lemon Pledge: we all know it’s used for cleaning furniture. HOWEVER! .... this is the best stuff ever for restoring clouded-up vinyl back to its full transparency.
I found out about this from a sail making shop that makes racing sails with vinyl “windows” in them. That shop would also get calls to clean the big clear vinyl “walls” that restaurants use on their Patios in order to keep the elements at bay from their customers.
Current ride: 2019 Ural Gear Up, O.D. Green (“Jyoti”)
Blasts in the past: 2016 Ural Gear Up ("Shanti ")
2012 Ural Gear Up ("Tootles")
2009 KLX250, 2009 KLR650, 2004 BMW R1150GSA, 1966 Honda 305 SuperHawk
“Your life comes with a lifetime guarantee.”
Post by Lofty » Thu Nov 21, 2019 7:07 pm
From my can of Pig Spit:
Contains: hydrocarbon propellant, CAS #68476-86-8; aliphatic hydrocarbon, CAS #142-82-5.
The CAS number for silicone is 90337-93-2.
The Pig Spit coating is designed to be sprayed on to a vinyl, painted or plastic surface, thinly, and immediately wiped dry.
More to the point, it's difficult to envision even the dullest individual spraying silicone (from any product containing it) in excessive quantity, and/or in close proximity to the air intake of a running engine, sufficient to create a bona fide hazard to adjacent oxygen sensors.
Perhaps the foregoing does in fact happen. S100 is sold as a general cleaner and is observably foamy when dispensed. We've all seen the YouTube videos that serve as examples of how not to perform a particular task.
Post by harryball » Thu Nov 21, 2019 7:18 pm
I'm going to give some pig spit a try. Just looking to brighten up the blacks on the frame etc...
Post by Lofty » Thu Nov 21, 2019 8:23 pm
You should be pleased with the results, Robert. As I said in a preceding post, it worked for my purposes when truly nothing else did.
Let us know how it works for you.
