WANTED: Some Kind of Wheel Hub
Got some Russian bikes or parts you want to buy or sell? Advertise your wares here. Individuals only - No dealers in this section please.
This section is for individual forum members to buy, sell, or swap bikes, parts or accessories. Once the item has sold, please edit your post and put "SOLD" in the topic subject title. Dealers and other commercial entities need to post in "The Gray Market" section. All listings must be motorcycle related, preferrably for Urals or Dneprs. No guns, real estate, etc. All items must have an asking price or what you are willing to trade for. No auctions or bids here. If you want to auction an item, put it on eBay and post a link to your item's auction on eBay here.
Post by Tomcatfixer » Fri Mar 22, 2019 6:50 pm
Knowing I have a penchant for restoring things, the generous (and practical, since he's moving) DneprTim gifted me with a rusty ol' 19" steel rim.
While I have painted and trued wheels, I've never built one up from scratch and I would like the experience.
I figure I'll make a good 19-incher with whatever kind of hub I can score cheap. I'll paint or powder-coat the hub and rim, install some new spokes and nipples that I'll buy, then, maybe, sell it. Or not. Or raffle it. Or donate it (depending upon spoke pricing) to a rally. I don't know WHAT I'll do with it, but I know I want to learn how to lace.
Before I buy a hub from a dealer, do any of you have a "loose" hub or an unsalvageable rim with a good hub inside?
Re: WANTED: Some Kind of Wheel Hub
Post by jaybird » Fri Mar 22, 2019 8:42 pm
After building some wheels with mixed random parts, I suspect that the rims that were made to work with IMZ "bottlecap" hubs are different than the rims that were made to work with later cast hubs, not sure about mixing in Dnepr/KMZ parts, and of course the spokes are all different between the three styles of wheels.
Something to consider.
Maybe one of the "Experts" will chime in and square things up, it should be an easy answer for the one eyed Ural king.
Post by Tomcatfixer » Fri Mar 22, 2019 9:50 pm
While I realized that the hubs of different sizes will require different spoke lengths, I hadn't considered any issues from a potential rim/hub mismatch. Perhaps DneprTim knows the type and vintage of the rig from which this rim was sourced. 🤔
Waffl6
Post by Waffl6 » Fri Mar 22, 2019 11:21 pm
Wait, how come you didn't tell me about this today? I saw that rim up against your shed.
Lemme know when you give up on lacing/truing and I'll help you out! I learned from the best.
No longer the youngest guy in the room, nor the youngest Ural owner on the East coast. Title lost to PeninsulaRider.
Current bikes: 1987 Rebel 250, 1990 Ninja 500, 2009 Honda Shadow 750, 2006 CBR600F4I, 2011 Ural Patrol T - I'm bad to her, so she's bad to me.
Past bikes: 1994 Katana 600
Fairfax Virginia
Claus
Post by Claus » Sat Mar 23, 2019 10:43 am
This rim (if it is a Dnepr rim) can be laced with a Dnepr hub
or with a Ural "bottle cap" hub
Both hubs will fit with the appropriate spokes.
Neither modern Ural drum brake hub nor hubs for rotor disc brakes will fit.Bulges and drill holes are oriented to the wrong side
owned bikes: 93 Ural rig domestic model, 95 Suzuki DR 650 RSE, BMW R100GS, Suzuki GSX1100G rig, BMW R100R rig with Ural sidecar, Ural rig with BMW drivetrain under construction,
Post by Tomcatfixer » Sat Mar 23, 2019 12:11 pm
Danke for this guidance, Claus! Now, I've just got to figure out it it's an old Ural/Dnepr or modern Ural rim. 🤔
Claus
Post by Claus » Sat Mar 23, 2019 1:08 pm
Sorry Chad, I should have written that, too.
If the first drill hole on the right side of the tube valve points down it´s a Dnepr/old Ural rim. if the first drill hole points up its a modern rim.
This said with the rim on a table and looking across the rim onto the valve´s hole (I hope, I could express myself adequate)
Post by Tomcatfixer » Sat Mar 23, 2019 5:03 pm
Well, then, that appears to be what we're dealing with here. Thanks for the education!
SO, anyone got an old Ural bottle cap or Dnepr hub? :wink:
Post by jaybird » Sun Mar 24, 2019 12:57 am
I suspect there may also be a difference between the modern Ural steel wheels in regard to drum brake or a steel wheel for front disc brake.
Thanks for that information Claus.
So it would be; valve stem hole at 12 o'clock with the first closest spoke hole positioned to the right of the valve hole?
Post by Tomcatfixer » Sun Mar 24, 2019 6:11 am
Apparently. ...and it doesn't matter which side of the rim you observe, in this case, because no matter how you lay it down, the spoke hole on the right always points down.
Claus
Post by Claus » Mon Mar 25, 2019 4:27 am
That´s right. And I have no clue about the hole orientation for disc rotor brakes.
thefixxer1965
Post by thefixxer1965 » Wed Mar 27, 2019 9:21 pm
i have a 19 wheel i got from crawford i changed my mind and am not using. its a chrome rim with a aluminum drum brake hub i gave $240. make an offer. i can bring it to CRAP. its a complete wheel bearings and all.
Post by Tomcatfixer » Wed Mar 27, 2019 9:49 pm
I'm sorry, you must not have read my original post.
I don't want a wheel.
I want to BUILD a wheel... for the experience.
Preferably for as little expense as possible.
You could advertise your wheel on the 2019 C.R.A.P. thread, however.
Post by BigJames » Fri Apr 26, 2019 8:50 pm
fun fact, bottle cap spoke pattern matches a certain US manufacturers rims, late model hubs don’t. No idea which rim you have! Having built a few wheels all I can add is have fun. Once you get started, it’s almost zen like. Then you have to attempt truing what you just built. With old Urals closeish is goodenov.
Post by Tomcatfixer » Fri Apr 26, 2019 10:01 pm
Would that manufacturer's name sound anything like "Hardley Ableson"? 🤔
