Weather proof gps
Weather proof gps
I'm sure this topic has been covered many times but was wondering what people purchase for a weatherproof GPS. Two people mountain to their handlebars or did the mount them to the side car so the passenger can help navigate? Any suggestions would be greatly appreciated thank you
1995 harley sportster
2001 harley sportster
2005 Kawasaki concours
2005 ninja 250
2008 honda goldwing
2009 Kawasaki ninja 250
2012 Kawasaki concours 14
2013 Kawasaki ninja 250
2015 Yamaha r3
2016 harley ultra classic
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
Re: Weather proof gps
I have a garmin zumo 550. Works great. No issues in 5 years.
- Andy
Everyday. No excuses.
2013 Patrol
2013 Patrol
mtrdrms wrote:I have a garmin zumo 550. Works great. No issues in 5 years.
How is it powered? Internal battery or does it need to be plugged in entire time??
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
It has an internal battery that will run for a few hours but I have a permanent, hard-wired mount on the bike. They're not cheap but they're the best for motorcycles.
- Andy
2013 Patrol
2013 Patrol
I would strongly suggest you go to Garmin and other manuf websites to read up on their current line of products. Searching for reviews on certain models as you narrow down your search will help as well.
As far as I know, pretty much all GPS units intended for cars are not weatherproof.
Motorcycle and marine units are normally, at the veryleast, water resistant.
Another consideration is being able to see the screen when in direct sunlight. Most car unit screens will not be easy to see in direct sun.
Another consideration is being able to operate touch screens with gloves on.
As much as I don't like Garmin the company, there products are probably the best. They normally make two models for motorcycles, one a regular GPS with a few added features and a second with all kinds of whizbang stuff like the ability to store and play music. I have a Zumo 390LM that suits my needs. My only complaint is the mounting system is poorly thought out. This shortcoming is typical of Garmin. The unit comes with a RAM mount for bikes. But the wiring is intended to be hardwired to the bike and includes a bulky transformer. The other mount, which is a typical car type mount, will not keep the unit fixed in position on a bike due to the bumpy ride. So, if you have multiple bikes and want to use the unit on all of them, it does not lend itself to that unless you buy a RAM mount and cable for each bike. The unit will take a mini-USB cable with a cigarette socket plug for car use. But the bike mount partially blocks the ability to use that cable. I am currently in the process of modifying the bike mount bracket to allow the use of the mini-USB cable so I can use it on various bikes. It requires a RAM claw mount, another GARMIN RAM bike mount. Probably about $90 in additional mounts. Hence, this is a primary reason why I don't like Garmin.
What you might consider in the interim is to use your smart phone with a handlebar mount. Granted, you need a cell signal for the GPS feature to work, but it will tell you if you really will use a GPS or it is just a passing fancy.
Certified Blatherer
Certified Blatherer
- Tin Man
- Commissar
Using the search feature, type in GPS and stand back. There are many good units available depending on what your plans are.
Here is a start:
http://www.sovietsteeds.com/forums/view ... lit=garmin
I still use my Garmin in its Ram mount. I believe it was intended to be a "handheld" but works quit well as my speedo, clock and odometer...............and its "backtrack" feature has gotten me back to civilization more than once.....
Here is a start:
2007 GearUp (Arctic #1)
130/45 jets, KTM rock solid mirrors, Delaware Dave's outstanding trunk lock, Mr. Cob's most excellent skid plate, Cycra Probend smashproof hand guards, Duro strong like bull 307's, RotoPax damn near bulletproof fuel cans, MKIII all but water proof air box and Dimples super duper magnetic drain plugs all around...oh yeah, and a manual fuel petcock.
.........if you see something that needs doing, just do it........
Man that stuff sounds complicated. Maybe I'll just buy some bettet paper mapsand hand them to my fiancé to help navigate while on the back roads.Snakeoil wrote:I would strongly suggest you go to Garmin and other manuf websites to read up on their current line of products. Searching for reviews on certain models as you narrow down your search will help as well.
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
Started with the search function but saw thousands of threads and got anxiety instantlyTin Man wrote:Using the search feature, type in GPS and stand back. There are many good units available depending on what your plans are.
Here is a start:
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
I looked this up On amazon but did not find the same modelmtrdrms wrote:I have a garmin zumo 550. Works great. No issues in 5 years.
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
2005 ninja 250
2008 honda goldwing
2015 Yamaha r3
Kymco like 200i
2016 suzuki dr 200
2017 ural patrol
Binghamton NY
- lendrinkard
$100.00 unit. Fodsport GPS.
Works well and is cheap and waterproof.
https://www.aliexpress.com/item/4-3-inc ... 96559.html
Feature Operating System Version: Win CE 6.0 CPU: Media Tek MT3351 486MHz RAM: 256MB Bluetooth 2.0 Waterproof Rating: IPX7 Speaker Power Source: Rechargeable Lithium Battery or Car Cigarette Charger or Car/Motorcycle Battery Power Usage Time: 2 to 3 Hours Systerm Languages: English, French, German, Italian, Spanish, Russian, Romana, Finnish, Polish Hungarian, Portugues
Specification CPU: MSTAR 2531 800MHz Memory: MLC 8GB Flash Memory, 256MB RAM Display: 4.3'' inch TFT LCD, 480*272 Pixels 16:9 Bluetooth: Bluetooth 2.0, Support A2DP Earphone Battery: Non-removable Rechargeable Lithium Battery, 1500mAh Waterproof: IPX7 Grade
GPS Frequency: 486MHz Signal Channels: 22 Hot Startup Time: 2s Warm Startup Time: 32s Cold Startup Time: 35s Voice: 120decibel (MAX) GPS Module: High Sensitivity Receiver Built-in Antenna
2012 Gear up - 130/40 jet, 3 shims, no mid-pipe, drilled slider, 2013 Branch pipes, all LED lights
2013 NOS Ural T - 130/42 jet, 2 shims, LED running lights, oil cooler
- New Member
Zumo 695lm, 395lm and 350lm are the current models. https://www.revzilla.com/garmin-motorcycle-gpsBunker wrote:I looked this up On amazon but did not find the same modelmtrdrms wrote:I have a garmin zumo 550. Works great. No issues in 5 years.
I have the 665 LM on a Twisted Throttle mount on top of the handlebar clamps. It's the model with SiriusXM, so I've routed the puck to the top of the tub. It, as well as my cellphone, connect via a Sena. Makes a leisurely ride a pleasure. I also used to have their cage mount for it on a Uly, but that's been sold. The point is: There are ruggedized mounts available. I've got a Zumo 550 that I'm trying for the monkey... Haven't mounted it yet.
San Francisco Bay Area
2015 Ural Gear Up
2014 Ural T
2016 Road Glide Special
2016 DL650 XT ABS Adventure
2016 Softail Slim
1983 BMW R65 w/Bingham MKIII sidecar
2015 Ural Gear Up
2014 Ural T
2016 Softail Slim
I have my Iphone on a RAM mount that I use for gps. I just cover with a Ziploc bag - works fine.
110,000 km and counting
Doubt you'll find any electronics that are waterproof. Water resistant but not waterproof. Factory waterproofing is basically spraying the internals with a silicone spray. The cases/cable connections can still leak. I've had a Garmin 60csx on a KLR and an old 279(6?) on a BMW. Both mounted to the handle bars. I put a ziplock bag over them with a rubberband securing the bottom of the bag. No issues. Still have the old 60 series but don't mount it to the Ural, I just keep it in my jacket pocket till needed.
- bgenest
I have a Tom Tom Rider 5 (2013 model) mounted to my handle bars. I have "lifetime" maps and use it when I am exploring in Maine. I am satisfied with it and it meets my needs. But, ALL GPS manufacturers reduce/stop product support after several years. If you go for an expensive Garmin or Tom Tom it will have a limit on its support and accessories. I tried to purchase another mount and cable from Tom Tom recently and they said the accessories were no longer being made for my model. Tom Tom has a few accessories listed, for my model on the EU website but they will not ship to USA. Emailed USA website a few times, no response. Tom Tom just released its newest motorcycle GPS. It's pretty slick but just as expensive as a Garmin.
As for the Chinese brands I did buy a "cheap" model off Amazon but it would not work out of the box. I returned it with authorization but never got a credit or response from the supplier or Amazon. Just sayin', your experience may be different. Good luck.
2015 Burgundy Patrol "Stickee Monkee"
