Trans and Rear oil Choices
Re: Trans and Rear oil Choices
Post by RC20 » Wed Jun 20, 2018 7:35 pm
Let me tell you a story of regular oil.
-40 below, Bronco sat for a week or so, got laid off, started ok, would not move. Had to put it in low range and rock it, finally broke her free.
I knew it was low on oil but once started wanted to keep moving so ran out of town and got her all warmed up.
Got out my spare can of oil, opened it up. 10 minutes latter you could see a gollup starting to form, figured it would only take 2 hours for it to go into the engine. Now it was a lot warmer up on Chena ridge where I was but .....
So, I figured, lets put the oil under the heater, run 20 miles or so and try again.
Dang, flowed like, well oil.
Synthetic oil does flow easier in cold temps and it starts to show at 40 degrees. Worst wear on the engine is the start. Any oil that flows easier is vastly better than one that does not. Cycle batteries are marginal to start (pun) with. All good and you can run it longer. 10k in our Diesel VW.
100k estimated cycle driving:
Mechanic/Technician/Engineer: Switchgear/ Generators/Fire Pumps/Computer Controlled Building Systems
Post by chaos2 » Wed Jun 20, 2018 7:42 pm
that has been my experience, even with the same weight oils synthetic flows easier at low temps. I figured that out back in my limey car days, maybe things have changed.
Raceway needles
Modtop exhaust
Urtigeral
Post by Urtigeral » Sun Jul 01, 2018 6:55 pm
I went from Mobil 1 20-50 full synthetic in the gearbox to Redline Lightweight shockproof (bought the wrong one) to redline heavyweight shockproof.
The lightweight shockproof didn’t feel any different to me than the Mobil 1. The Heavyweight shockproof does—it’s still a Ural gearbox but it does feel like there’s a slight cushion when shifting now. I like it.
Post by hotflash44 » Sun Jul 01, 2018 8:04 pm
Urtigeral wrote:I went from Mobil 1 20-50 full synthetic in the gearbox to Redline Lightweight shockproof (bought the wrong one) to redline heavyweight shockproof.
i agree, i use redline 20w60 in engine and hd shock proof in the other two,all good so far. :cheers:
