Dnepr oil pressue light
uhg14
Post by uhg14 » Sat Sep 16, 2017 3:54 am
Hi
I have a Dnepr MT 10-36 with 8,500 km on the speedometer.
I use 20w-50 oil.
The motorcycle run nicely and I neve pass 70 km/h.
After a ride ofb about 20-25 min the oil lamp lights while idling.
The cylinders temp is acceptable (170,150C). There is no starnge behavior or noises.
Should I raise the idle RPM?
Any other ideas?
:shock:
Nathan
propwash
Re: Dnepr oil pressue light
Post by propwash » Sat Sep 16, 2017 9:03 am
Try another sender or better yet, plump in a pressure gauge.
The cheap oil pressure test sets at HF have a fitting that will fit the Dnepr case.
IIRC, seeing 35-40psi at idle is common.
sallen
Post by sallen » Sat Sep 16, 2017 8:05 pm
propwash wrote:Try another sender or better yet, plump in a pressure gauge.
+1 on the pressure gauge
19?? Dnepr MT16
2008 Gear Up / Orange camo
130/45 one shim
drilled slides
A statement I live by.
Panic is a luxury you can afford after it is all over.
Bilgekeeldave
Post by Bilgekeeldave » Sat Sep 16, 2017 8:11 pm
I put a glycerin filled oil pressure gauge on my Dnepr. They last longer than the cheap oil pressure gauges.
Dave
RAMCO-Dnepr MT-16
uhg14
Post by uhg14 » Sun Sep 17, 2017 9:24 am
Thank you
