Axle Grease
Re: Axle Grease
Post by Tomcatfixer » Thu Jun 22, 2017 6:52 pm
Re: Axle Grease
Post by hotflash44 » Thu Jun 22, 2017 10:05 pm
Don't hit me, but what bearings can be removed and greased on the newer Urals?
Re: Axle Grease
Post by Tomcatfixer » Fri Jun 23, 2017 4:30 am
Upper and lower steering head bearings and all eight wheel bearings.
'Course, I'm doing a frame-up restoration on my '99, so replacing bearings is just par for the course.
EDIT - Corrected autocorrect.
Re: Axle Grease
Post by VWK75S » Fri Jun 23, 2017 6:02 am
rougaroo wrote:I've been a fan of the red axle grease. Rougaroo
Pennzoil wheel bearing grease 707l what I use :)
2009 GearUp 150,000kms
Re: Axle Grease
Post by hotflash44 » Fri Jun 23, 2017 9:00 am
thanks for the info ,i forgot your rebuilding a 1999 Ural, with combined pics/and stuff it looked like your regular ride was falling apart. was starting to feel sorry for you LOL.
Re: Axle Grease
Post by hotflash44 » Fri Jun 23, 2017 9:04 am
TCF, so the wheel bearing on the wheel can be greased. Are they like car bearings that have a grease seal and easy to remove and grease by hand? Do the new Urals have wheel bearings that can be greased?
Re: Axle Grease
Post by rougaroo » Fri Jun 23, 2017 11:30 am
Forget the year (check Terry Crawford's site for year-by-year changes), maybe 2007, but since then all Urals have sealed wheel bearings. No maintenance but check from time to time for reassurance. Before that they had the roller bearings Chad's showing. Greasing was an every 10,000km job, shown on BillyG's http://www.myural.com site.
Grease seal was inside the bearing nut on the outside of the wheel. The new sealed bearings don't have that seal, though they have the same nut.
If you order a new wheel hub to replace an older one it will come with the new sealed bearings installed.
Re: Axle Grease
Post by hotflash44 » Fri Jun 23, 2017 12:31 pm
thats what i thought new Urals are different.
Rummer151
Re: Axle Grease
Post by Rummer151 » Tue Jul 11, 2017 11:46 am
Wonder if a navy buddy would send me some mil spec 24508 ball and roller bearing grease.
Used that stuff on steam turbines and it is amazing!
Ben B.
MM1 (SW) USN, 15 years
Keokuk Iowa, 52632
Titled 1973 Dnepr (1990ish mt-11)
1976 XLCH 1000 Sportster (project)
1987 FLHTC HD Electra glide classic
2000 HD sportster 1200C (sold)
Roni
Re: Axle Grease
Post by Roni » Tue Jul 11, 2017 3:23 pm
On an unrelated note, if you have a Harley Davidson, don't use axle grease on your axles (and always consult the Field Service Manual first, because failure to do so may result in injury or death). Apparently, you need "Anti Seize Lubricant" instead of axle grease. If you don't, you might wind up having to pound your axle out of the swing arm and hub with a hammer and punch, destroying the axle and wheel bearings in the process.
Please don't ask me how I know this.
'07 Sportster XL1200C (Talulah)
'04 Troyka (Riba)
'82 CM450C (Zenaida: gone but not forgotten)
