Car oil vs motorcycle oil?
DesertRat
Re: Car oil vs motorcycle oil?
Post by DesertRat » Fri Feb 03, 2017 12:05 pm
Emoore wrote:Not to start a sideways conversation, but there is a big American Bike company out there with air cooled engines that use Motorcycle 20W50......they even have there own brand of synth oil too in 20w50.... Might need a look into it.
Just tossing wood on the fire, but could this work as well?
"Their own brand" is just something else repackaged. I think it's Redline.
2009 Sahara
Slides drilled, 2 shims, Yamaha petcock.
sean026's steering damper (the best modification ever!)
Emoore
Re: RE: Re: Car oil vs motorcycle oil?
Post by Emoore » Fri Feb 03, 2017 1:17 pm
Don't know what it is, but they put that stuff in everything and charge you for 2 oz of gold....
Sent from my SAMSUNG-SM-J320AZ using Tapatalk
Ernest
2003 Patrol (Medusa)
2012 Ural T Olive (Roulette)
2017 Ural CT ( Grey Hex)
Yamaha FZ07 ( My need for speed )
Wake Forest, NC
John Wayne - Life's Hard. It's Even Harder When You're Stupid.
Bilgekeeldave
Post by Bilgekeeldave » Fri Feb 03, 2017 2:13 pm
I googled it, Citgo makes Harley Davidson motor oil, it used to be Sunoco.
Dave
RAMCO-Dnepr MT-16
Aufgeblassen
Post by Aufgeblassen » Fri Feb 03, 2017 8:15 pm
MartyL wrote:NO!!! Do not use car oil in a motorcycle... Don't screw around with this....
LOL! The ONLY reason car oil is not recommended is because your wet clutch "may" slip a little easier. Since no wet clutch, car oil PERFECTLY fine in ANY dry clutch bike.
Stryker
Post by Stryker » Sun Feb 05, 2017 4:12 pm
Emoore wrote:I have been researching the engine and URAL recommendation, and help from this thread and I have decided to go Amsoil full synthetic Z Rod for flat- tappet camshafts like ours.
That is pretty much the same conclusion I came to.
Where are you in NC?
2016 GU Sportsman
1968 Ducati 250 Scrambler (long gone)
Post by rivers » Sun Feb 05, 2017 4:19 pm
Yes folks, I agree, by all means put oil in the motor.
URAL CT
Post by URAL CT » Sun Feb 05, 2017 8:46 pm
Here's my 1 cent worth: from what I've read, today's oil in general have a very much reduced zinc content. Studies found that Zinc causes degradation, then failure of the catalytic converters in modern vehicles. So, the EPA stepped in & mandated the gradual reduction of Zinc in modern oil formulations. The Ural, like old school bikes, have flat tappets & zinc provides lubrication properties to the metal to metal contact. ZDDP additives are sold mostly to hot rod enthusiasts...yep, they're still around. Yeah...back in the old days before the EPA, automotive oil was used in motorcycles cuz like most cars of yesteryears they had flat tappets. We were also not as conscious about the environment as the majority of us are today. I started adding ZDDP to the dyno-mix oil I used & quieted the engine some & seem to run cooler...power of suggestion...maybe??? I currently use synthetic oil (20w/50) with high Zinc contents. It was developed for the hot rod enthusiasts of today. My Ural is just happily humming along. :mrgreen:
CT
2007 Patrol
Plano, TX
Emoore
Post by Emoore » Sun Feb 05, 2017 9:25 pm
Wake Forest. You?
Ernest
Wake Forest, NC
Emoore
Post by Emoore » Sun Feb 05, 2017 9:54 pm
Ernest
Wake Forest, NC
URAL CT
Post by URAL CT » Sun Feb 05, 2017 11:00 pm
Been using the Z-Rod since July 2016...so far so good. Negligible swarf on the mag drain plug. Rig seem to run cooler too. I'm monitoring the oil temperature to find out how hot it'll get. I'll put this oil through a real road test this coming summer. I'll be scooting around the Western US & Vancouver Island, Canada. :wink:
CT
2007 Patrol
Plano, TX
Stryker
Post by Stryker » Mon Feb 06, 2017 5:39 pm
Wake Forest. You?
In Columbia, CT now but spent half of my youth in Charlotte, my brother is in Kernersville.
2016 GU Sportsman
Johnwesley
Post by Johnwesley » Mon Feb 20, 2017 9:53 pm
I used valvoline vr1 oil in the 64 vw. Was said to be for the flat tappet cam, has plenty of friction modifiers for older motors. Marketed as "racing" oil which allows it to get past EPA regulated additive packages.
Would this be a good oil for the ural 750? Just courious since I just picked up one and want to do a fluid change before riding.
2007 patrol
2005 Superglide
2015 Cheiftain
