Turn Signals
URALNUT60
Turn Signals
Post by URALNUT60 » Thu Jun 04, 2020 7:17 pm
Have noticed turn signals on my 97 650 ural has gotten weak and at times flat out dont work, Denso altenator, main ground cleaned, modern flasher installed, all fuses replaced and fuse block cleaned up, any pointers on what i might of missed? Thank you
Who's Ur Grandaddy ?
Re: Turn Signals
Post by Who's Ur Grandaddy ? » Thu Jun 04, 2020 7:37 pm
Dirty contacts on switch?
Old and intermittent bulb?
john
2013 FF gear-up
Mr Cob bulletproof skid plate
7/64 drilled slides
Leftka III type airbox
Modtop mufflers
Oregon
URALNUT60
Re: Turn Signals
Post by URALNUT60 » Thu Jun 04, 2020 8:05 pm
Left that out on post, cleaned switchgear, replaced bulls 3 yrs ago when purchased, prob také bulbs out and clean sockets, thank you for your input
Re: Turn Signals
Post by wooden nickel » Thu Jun 04, 2020 8:16 pm
On a bike that old if the easy stuff like bulbs, sockets or switch doesn't cure the problem, check the grounds and wire connections. Also the flashers do die sometimes but it isn't the first thing I would suspect.
Re: Turn Signals
Post by Wildhorse Cafe » Fri Jun 05, 2020 12:30 am
Maybe a bad flasher module. My best guess.
Re: Turn Signals
Post by Lofty » Fri Jun 05, 2020 3:28 pm
Have noticed turn signals on my 97 650 ural have gotten weak and at times flat out don't work
In the few instances when I've had to deal with the same, a malfunctioning flasher module (usually the aged OEM original) was to blame. Replacing it with a fresh, factory equivalent module restored proper functioning, every time.
Re: Turn Signals
Post by Tomcatfixer » Fri Jun 05, 2020 5:19 pm
If it IS the flasher relay and you opt to upgrade to a modern unit, you may choose to salvage the original relay's integrated mounting bracket, as I did. The super glue has been quite effective in keeping the relay securely in place.
Re: Turn Signals
Post by Lofty » Fri Jun 05, 2020 6:10 pm
Mild thread drift:
I'm fond of the controlled-dispensing super glue bottle design pictured in TCF's post. It's been necessary for me to purchase them in 3-packs, though. The size of the bottle gives the illusion that there's significantly more glue therein than its design and attendant functioning will permit.
And so I've had to hurriedly open a new bottle whilst in the middle of a delicate job -- aren't they all, when having to use cyanoacrylate? -- and the squeezings aren't providing any more precise drops of adhesive.
darkhorse
Re: Turn Signals
Post by darkhorse » Fri Jun 05, 2020 8:18 pm
I did something similar to Chad except used a zip tie where Chad used super glue. The part number for the flasher I bought is listed here. The electronic flasher blinks faster and more frequently than the original thermal type flasher. Many would say its a little safer that way.
viewtopic.php?f=5&t=51886&p=657765#p657765
2001 Ural Deco Classic
PowerArc Ignition
Mikuni VM28 Carburetors
Inertial Supercharger
URALNUT60
Re: Turn Signals
Post by URALNUT60 » Sat Jun 06, 2020 4:54 am
Yes already swapped OEM flasher for never style while back! Thanks guys
