Wheels not in the same plane
Vato
Post by Vato » Thu May 07, 2020 4:44 pm
I have 2019 GU with 1500 miles. This my second ural, I have owned Urals for 5 years and do my own wrenching. The '19 has always pulled right on a flat straight road at 40 mph with the throttle lock on. I have redone the alignment several times and it has improved. But, not neutral letting go of the bars and it is immediately heading for the ditch. Current setting are - Toe in 9/16" at end of tires, Lean out 2.4 degrees. Sidecar is level side to side.
Today I was rechecking the alignment and I noticed the lead edge rear wheel is 1/4 " out heading to the right. Measured from the rim and I rotated the wheel to check trueness. Now I know why it pulls right.
Has anyone had this problem? Bent frame, bent swing arm, or poor assembly?
If it was a chain drive an easy fix but.....?
I do have a warranty but I'm afraid they will have it forever.
Thanks
Re: Wheels not in the same plane
Post by Lmo » Thu May 07, 2020 7:08 pm
Or it will pull to one side forever...
Sorry, I don't understand your meaning.
Motorcycle is leaning away from the sidecar 2.4°(which seems like more than needed (to me)).
Are you saying that the rear axle might be canted to the right (as viewed from above)?
Vato
Post by Vato » Thu May 07, 2020 7:47 pm
[/quote]
Or it will pull to one side forever... LOL
Yes
Post by RC20 » Thu May 07, 2020 7:53 pm
Vato:
My take is this is the single most vexing issue (alignment and pull) on the newer Urals, probably plagued all of them back to 1041, but in Russia in the mud who knew? And until they got where they would go more than 45, well men were men, and real men just get more muscles (or something like that)
There are other reports on non alignment (mine appears to be slightly off as well and yes I have some right pull issues though I got most of it worked out.
There is a recommendation that if it goes right you add more lean though you are quite far over.
How are you fore and aft for level (various placed you can put a level on the frame, Torpedo up top, cross bars under of the outside run there as well.
Post by Snakeoil » Thu May 07, 2020 8:39 pm
There have been reports in the past here about rear wheels not being straight relative to forward motion. FD pretty much controls the position of the rear wheel. So, you can do some measurements to determine if the swingarm is tweaked. Measure from center of axle to center of swingarm pivot. If okay, could be swingarm pivot points are not perpendicular to axis of frame/direction of travel.
Having measurements to make your case may help with your dealer discussion.
Post by jaybird » Thu May 07, 2020 9:56 pm
There have been instances of the swing arm being improperly assembled , if you search around on here you can see where some people have shimmed it with washers.
I would utilize the warranty.
Post by rougaroo » Fri May 08, 2020 9:19 am
Definitely a warranty issue, but an interesting geometry problem.
If your pusher heads 1/4" towards the right but is true on the axle, that points to the swingarm or the frame. One idea might be to measure from a left-side motor mount to the left-side swingarm, center-to-center, then do the same on the right. Have to be pretty accurate, though, because it wouldn't take much to create a 1/4" offset. 1/4" offset at the tire edge is only 0.00328" at the axle.
If the motor mount-to-swingarm distance is the same, then check the swingarm bolt to axle measurement the same way.
If the wheel is true, something has to have shifted the axle alignment. Pure speculation on my part but bad weld, maybe someone backed into you on the left beam of the bike?
Interesting problem-
Post by Mr Wazzock » Fri May 08, 2020 11:43 am
If the front of the pusher is angled to the right, it would make the rig steer left surely? Image
Vato
Post by Vato » Fri May 08, 2020 12:32 pm
The sidecar is only level side to side. All that I have read/videos show side to side level. I will level front to back and repost.
Kaliram
Post by Kaliram » Sat May 09, 2020 9:24 am
I’ve had three Urals, 2012, 2016, and 2019, and they all have the pusher tire cockeyed to the right. Jason at Ural HQ doesn’t readily admit to the problem, but did mention that they’re going to outsource the frame mfg. in order to make a better aligned frame.
With all my bikes, i have just set the toe-in using a straight edge on the right side of the pusher only, which is the way all other sidecar outfits do it. . It will be about 1/2” off to the right of the front tire.
....then there is the c. 1 degree difference in the lean out of the front and rear tire! I just set the lean-out measures off the rear brake rotor.
2012 Ural Gear Up ("Tootles")
Post by Lmo » Sat May 09, 2020 5:46 pm
The sidecar frame may be 'level' but is the sidecar WHEEL perpendicular to the road.
My sidecar frame is not level, but I have the chair set up with the wheel perpendicular.
edit
