Crankshaft bearing shields: an option?
Post by Tomcatfixer » Fri Apr 10, 2020 4:41 pm
I'm preparing to simultaneously overhaul five Ural engines...
...and, as part of the process, I'll be replacing a bunch of old Russian bearings with quality modern bearings...
...but, I've got a crankshaft bearing question.
The conventional wisdom is to use an unshielded rear crank bearing so that the oil can flow through the bearing to properly lubricate it, then drain out the hole at the bottom of the bearing carrier plate.
The thought was that, despite the advantage of reducing the possibility of a rear main seal oil leak, having a shield on the rear side of the rear crank bearing would inhibit proper bearing lubrication oil flow.
I would love to reap the oil leak reduction benefits of a rear shield, but not at the expense of sufficient bearing lubrication.
I've seen other Uralista try to get the best of both worlds by cutting notches in the shield, like this...
What is the opinion of the Collective on such a strategy? Maybe cutting a few additional notches, as well?
Re: Crankshaft bearing shields: an option?
Post by Snakeoil » Fri Apr 10, 2020 4:49 pm
:lurker:
Manscout
Post by Manscout » Fri Apr 10, 2020 5:23 pm
Hmmmm. I am going to show my incompetence, but why a shielded one? If there is a drain hole on the back-side, isn't oil going to get there regardless?
2011 Ural Patrol
Gillette, Wy
Instagram: manscoutwyo
Post by Tomcatfixer » Fri Apr 10, 2020 5:43 pm
Theoretically, the shield will help keep the oil from seeping past the rubber rear main seal to the clutch bellhousing.
The drain hole returns the oil back to the sump.
Post by Tomcatfixer » Fri Apr 10, 2020 7:30 pm
I hauled out all of the "patients", so you get a better visual of the situation. :|
Post by Snakeoil » Fri Apr 10, 2020 8:30 pm
How did you end up with so many engines?
Post by Desantnik-VDV » Fri Apr 10, 2020 8:35 pm
Oil also lubricates rear seal around the shaft.
The rest is just history.
Post by Tomcatfixer » Fri Apr 10, 2020 9:40 pm
This is true, and there will still be oil in the space between the bearing and the seal, especially if I notch the shield... just not as much oil. Will this increase rear main seal wear? Maybe. That's why I'm asking the Collectives' opinion.
- One 650 is from my '99 Tourist project bike. It has not yet run under my ownership, but it has a lovely shade of beige baked onto it.
- One 650 is from my '01 Patrol, which has developed some annoying oil leaks. It ran fine, but after tearing it down so far, Jaybird convinced me to just go ahead and replace the Russian crank & cam bearings while I was at it.
- The kickstart-only 650 is from the mystery vintage Tourist I recently acquired from eastbloc. It came with no cylinders installed. I'm guessing it's an early U.S. import.
- The shiny 650 crankcase, I received from a friend of BigJames. It arrived full of water, leaves, mud, and rust, but amazingly, the crankshaft spun freely and felt great (still gotta measure it, to see if it's salvageable).
- The 750 is a blown motor I bought off of a guy that decided to convert his Gear-Up to electric drive. It's the basis for my 825cc project. I've got the Big Russian Pistons, just gotta get a local machine shop to bore out the jugs.
I've also got the 2015 engine in the Mobile Chernobyl, but I'm hoping that I don't have to remove it any time soon. :wink:
Post by Snakeoil » Sat Apr 11, 2020 1:30 pm
My 650 had an oil slinger that went on between the bearing and the seal. I inadvertently left it out because it was put in a bag with the old bearing. Found it after bike was running. Did you not find a slinger on the back of any of your 650 cranks? It's simply a sheet metal disc that slips over the crank.
Terry Crawford said not to worry about it. The new bearingI installed did not have a shield. It was an open bearing. I don't think the slinger did much as it was a truly awful fit on the crank. Terry said that BMW used a slinger like that on the /2 engines.
If I had to do it over again, I'd use the shielded bearing. Cutting a notch is not a bad idea. Allows some oil to get to the seal. Although I might just grease the seal.
Post by Tomcatfixer » Sat Apr 11, 2020 2:38 pm
All eight 650 and 750 crankshafts in my possession have oil slingers fore and aft.
Thank you for your input.
petermertos
Post by petermertos » Sat Apr 11, 2020 4:06 pm
Agree - cut a notch, it would be more than enough for oil to lubricate the rear seal.
2013 GU
2012 Solo
1999 BC
Portland, OR
Post by jeffsaline » Sat Apr 11, 2020 5:04 pm
I would probably consider using assembly lube when installing the bearing and seal. That takes care of the first minute or so after engine start up. I would also use the kicker to turn the engine to get the oil system primed prior to first start.
I don't know if the notch would make much difference or not but I sure wouldn't be opposed to notching.
Post by Tomcatfixer » Sat Apr 11, 2020 5:20 pm
I popped the two metal shields off of a 750 crank bearing. I removed one side with a scribe and the other with a small flathead screwdriver and, as you can tell, it was difficult to do without bending the shield.
I suppose I can re-flatten the portion of the shield I bent (I only need one shield) and attempt a notching and reinstallation. It's unfortunate that I couldn't pry it out of the bearing along the outer edge, because if I could, I would just create one of the notches where the bend was.
I wonder how well a notched rubber shield would hold up? It would be much easier to remove and cut.
Post by jeffsaline » Sat Apr 11, 2020 5:23 pm
Can you try the tip of a knife blade? Metal shields are difficult sometimes.
Edit addition: Just had another thought. Can you just drill a small hole or two in the shield with it in place?
BillyG
Thread Killer
Thread Killer
Post by BillyG » Sat Apr 11, 2020 5:57 pm
You don't need to notch anything. Pull one shield and leave the other alone. I did this on both crank bearings 150-200K km's ago. It don't hurt sh#t.
Bill Glaser
2002 Ural Patrol "CYKA"
