2012 Patrol - Lost Spark
MoJosDaddy
Post by MoJosDaddy » Fri Mar 06, 2020 7:47 pm
Hey all, Newbie here. I'm the proud pilot of a 2012 Patrol that has been nothing but a pure pleasure to own and operate, but I have suddenly lost spark. I've done some research and found that the hall effect sensors on these bad boys are problematic, so I thought I'd pick some brains to see if that is where I should start?
Everything has been reliable and firing fine, until I converted to the spin on filter front cover. Now I get no fire. Thoughts?
Re: 2012 Patrol - Lost Spark
Post by Lokiboy » Fri Mar 06, 2020 8:17 pm
That would be my first course of action. You might have dislodged or pinched a wire during the conversion.
Post by chaos2 » Fri Mar 06, 2020 8:43 pm
If it ran fine before before the conversion I'd retrace everything, something probably went back in the wrong place.
MoJosDaddy
Post by MoJosDaddy » Fri Mar 06, 2020 9:38 pm
Thanks! Already retraced and they ONLY aspect of the ignition system that was disturbed was the HES, so I'll get a new one on order and keep my fingers crossed.
Will report back when I get her back up and running 👍
2012 Ural Patrol
1986 Harley-Davidson FXR
Post by VWK75S » Sat Mar 07, 2020 7:43 am
You don't need to buy a new one to test it or the ignition.
But it is good to have a spare.
2009 GearUp 150,000kms
Post by Lokiboy » Sat Mar 07, 2020 7:52 am
How would you test it? I’m electrically challenged. :D
Bendog02760
Post by Bendog02760 » Sat Mar 07, 2020 8:01 am
Since you were in the area of the hall sensor I’d definitely think you inadvertently caused an issue. My 12 GU was giving me sporadic issues last year and I thought fuel starvation/ spark or vacuum leak. After checking everything I changed the hall and was surprised that it was the solution. Definitely a smart move to replace. Good luck. :cheers:
2012 GU (I bought in May 2017) All my GU rides are with my dog, Liberty
HD Road King
HD Wide Glide
Owned about 15 other HD over years
Boston Mass.
Post by VWK75S » Sat Mar 07, 2020 11:00 am
Ok, use a 12vdc led that draws about 20ma NOT a light bulb or an led cluster.
You could also use a multimeter set to read 12vdc instead of a led.
Any questions?
Hall effect.pdf
Post by S 854 » Sat Mar 07, 2020 12:07 pm
I’m “electrically challenged” too so I’ll leave the in-depth troubleshooting to other, smarter board members...
...however... have you checked the BRS?!?
Wouldn’t be the first time a person went diving into the electronics to cure a “simple” issue...
I know from experience... :oops:
MoJosDaddy
Post by MoJosDaddy » Thu Mar 19, 2020 9:41 pm
Hey all, sorry for the delayed update, the new HES and a 0.015" shim got me back up and running. So simple fix after all. Thanks again for all the help! :cheers:
2012 Ural Patrol
Post by VWK75S » Fri Mar 20, 2020 6:22 am
:boogie: John
edmKC
Post by edmKC » Sun Mar 29, 2020 11:52 pm
Yep, those HES are a weak point for my '12 Patrol. I've taken to carrying a spare after replacing it twice.
2012 Ural Patrol
2006 Honda GL1800
Previous bikes:
2010 Kawasaki Vulcan 900 Classic
1983 Suzuki GS850G
1982 Yamaha Vision 550
URALNUT60
Post by URALNUT60 » Mon Mar 30, 2020 1:48 pm
I believe Gobium has video on testing hall effect sensor, go to his video library, lemoto.com
