Need help to identify some parts I can't recognize
Post by Desantnik-VDV » Tue Dec 03, 2019 11:35 am
I don't remember what one package of parts are. Who know what this kit is for?
Looks like could be for carb, because in pairs...
Two o-rings with about 53mm ID
And two grommets with about 15mm
And then there is a pair of exhaust gaskets I think, and then some aluminum rings with 52mm or 2" ID (looks like for carbs?) and 4 small metal washers.
The rest is just history.
Who's Ur Grandaddy ?
Re: Need help to identify some parts I can't recognize
Post by Who's Ur Grandaddy ? » Tue Dec 03, 2019 12:03 pm
Don't know about the "o" ring picture . The aluminum rings are Raceway perch rings . They go on the airbox side of your carbs to give you a larger perch for your hose coming from your airbox. The red gaskets are heat shields . They mount on your heads where the rubber compliance fittings hold your carbs to the head intake. Put them against the head , under your existing gasket.
john
2013 FF gear-up
Mr Cob bulletproof skid plate
Powerarc ignition
7/64 drilled slides
Leftka III type airbox
Modtop mufflers
Post by Who's Ur Grandaddy ? » Tue Dec 03, 2019 12:06 pm
the o rings may be for the old style oil filter.
john
2013 FF gear-up
Powerarc ignition
7/64 drilled slides
Modtop mufflers
Post by Lokiboy » Tue Dec 03, 2019 1:32 pm
I think the O-rings are for the metal base of the oil filter
codemonkey001
Post by codemonkey001 » Tue Dec 03, 2019 1:36 pm
Yes, the o rings go at the base of the filter and the little rubber grommet fits inside the filter. The aluminum rings are perch rings - if you've still got the old air hoses, replace them with the new style. You'll thank yourself the second time you have to pull the carbs.
2007 Patrol - Starbug
BloNo Illinois
Post by Desantnik-VDV » Tue Dec 03, 2019 2:06 pm
Thanks guys. I will remove compliance fittings and install the heat shields gaskets. I have new stile intake hoses new in box.
I got the o-rings and gomets knowledge as well. Thanks.
Last Ural oil filter I changed was back in 2005 and that was a 1999 Deco Classic before I converted that bike to BMW R100 engine.
Many new parts in packages waiting to be installed and many yet to be ordered for a brand new 2007 GearUp NOS with 32 km on odo😃
codemonkey001
Post by codemonkey001 » Tue Dec 03, 2019 2:14 pm
Good lord, I thought the 2007 I bought was well preserved. I've never seen a Ural looking so spotless...now go get it dirty.
BloNo Illinois
Post by Desantnik-VDV » Tue Dec 03, 2019 2:46 pm
Bought yesterday brand sparkling new with 12 years gas in tank, carbs. Although camo GearUp cannot be sparkling 😄
“A blast from the past” or “Back to the future “.
Post by sKiZo » Tue Dec 03, 2019 5:59 pm
Had it running yet? I'd expect your carbs are varnished pretty bad if the fuel is that old. I'd also plan on flushing the tank - even regularly used, it's amazing the amount of crud that will find it's way into places it shouldn't oughta be ...
Post by Lokiboy » Tue Dec 03, 2019 6:51 pm
As for rust inside the tank. I’ve always had some sort rust in mine. Not ideal, but not a problem either. The petcock filters have restricted anything of consequence.
Post by Desantnik-VDV » Tue Dec 03, 2019 8:44 pm
Cleaning carbs, w@$#ing the gas tank. Got some Red-Kote, planning to apply inside the tank.
Factory carb jets were 38 idle and 125 main. Got new pairs of 42 and 130 for replacement.
Will need to buy a manual petcock and toss away that vacuum...
