New battery time?
Re: New battery time?
Post by RC20 » Mon Sep 09, 2019 11:42 pm
Wildhorse Cafe wrote:
Mon Sep 09, 2019 1:14 pm
Batteries start to die the second after they are manufactured. Five years is a good run. Any battery is suspect after two years.
Mostly wrong. They do start a long slow (if they are any good mfg) from day one, but it depends on all sorts of variable as to life.
My F-250 battery is 15 years old. Cold weather while it creates less chemistry activity for go pup, also preserves them.
Under the hood in Arizona, Nevada etc, that can be an issue. Then it depends on how much how hot etc. Still 3 years.
Ural is open so it gets lets heat beating. 5 to 10 would not be abnormal for a cycle battery.
Post by RC20 » Mon Sep 09, 2019 11:46 pm
I think you have a starter/cable/connection relay issue not a battery issue.
A load test is the very best you can do and if it passes, then the chemistry is doing its thing.
Your 10 mph voltage is a bit suspected, it should be full 14.8. Only an issue if idling a lot.
Lmo wrote:
Sun Sep 08, 2019 9:07 pm
1 - The Westco WCP15L 14aH/220CCA AGM battery in my rig is at least five years old. It's been performing well until very recently;
a - it sits on a digital battery 'maintainer' and will start the bike first thing in the morning.
b - it will start the bike, with the electric starter, after a 10+ mile cruise at 'highway speed'.
c - it will then fail to start the bike after a second stop ( i.e. running into the market ).
d - it kick starts with one kick.
2 - The alternator is making;
a - 11.49V 2 idle*
b - 12.8 above idle ( say 10mph in first gear )
c - 14.8V 'at speed'
3 - I had it load tested at O'Reilly Auto Parts and, surprisingly, it tests 'Good'
Regardless of load test, I think it's new battery time.
What says the collective?
* I didn't have my Harmonizer available to monitor RPM, but I would estimate 800-1000 RPM.
