Running Great Since I bought it. Now...
Paint shaker
Post by Paint shaker » Fri Sep 06, 2019 2:11 pm
Purchased the bike in 2012 from Holowpaw Gene. The bike is a 1995 sportsman with 2008 engine, final drive and transmission, has Ducati ignition. 33,000 KM when I bought it, 77,000 on it now. The bike has lived in Florida since purchased, until April 2019 and now resides in Tennessee. Prior to the move, the bike has been ridden in the mountains several times with no issues.
I have experienced 0 engine issues until the other day. Pre ride- oil level was correct. The day was warm (in the high 80's low 90s), but nothing it has not seen before. Bike ran great at the start of the trip. Fueled and about 45 min later stopped to look something up on phone. The bike began to sputter like it was not getting fuel while at idle. Stopped for lunch and let it sit. Started riding again and it wanted to sputter while idling or when leaving from a complete stop, but ran normal going at speed. Thinking bad gas, I topped off the tank with fresh fuel. The problem persisted so I went home.
Found the left side spark wire had melted through the insulation (exposing the wire itself) on a cooling fin of the jug. Replaced spark plug with solid core spark plug wire (waiting on new plugs).
Went for a ride last night and it was still doing the same thing.
Today, replaced all fuel lines and fuel filters. Checked air filter and was clean, but cleaned and re-oiled anyways. When warmed up, sprayed carb cleaner in the carbs.
Bike no longer sputters at idle, but when starting from a stop on flat ground it will act like it is running out of gas, even worse so going up a hill at low RPM. If I have enough momentum to overcome this and give it more throttle, the bike will eventually run like it is supposed to.
Any suggestions?
Current; 1997 2Wd Ural w/an 08 Engine, Drivetrain and Electronics not many mods, I just ride the thing! 1998 Buell S1W, 1998 H-D 883, 2004 Buell XB12R (Race bike)
Pevious; 1990 H-D Springer, 2001 H-D 883, 2008 Buell XB12R, 2006 Buell Ulysses, 2008 H-D FLHP Road King (work), 2010 H-D FLHP Road King (work) x3, 2012 FLHP Road King (work) X2
Re: Running Great Since I bought it. Now...
Post by Tomcatfixer » Fri Sep 06, 2019 2:17 pm
Clogged petcock? Debris in a carb jet? Clogged air filter?
Post by Lokiboy » Fri Sep 06, 2019 3:12 pm
Run in PRI just to rule out a vacuum problem. I’m with you, it sounds like bad gas.
The melted wire may have just been a coincidence. But, remove your plugs and see what kind of spark you’re getting. Maybe the coil was impacted - again just narrowing possibilities
Paint shaker
Post by Paint shaker » Fri Sep 06, 2019 3:27 pm
Update: Now only stumbles right off of idle, but runs ok after that.
The left cylinder runs approx 20-30 degrees hotter than the right side. No problem getting up steep incline unless really low RPM, but fine after that.
Post by stagewex » Fri Sep 06, 2019 3:43 pm
Good on you changing the filters and hoses. Undershirt and socks.
Now change your underwear (clean your petcock, flip your tank). At the very least drain the float chamber of your carbs or go all the way clean them thru & thru. Then flush the new hoses again. Even tiny debris can get thru the best of filters over the years.
These pix were after 4 years from new. Basically the same thing 4 years later. You said you purchased in 2012?
Normal maintenance.
If you really want to eliminate any and all possibilities about fuel starvation.
2006 Honda "Big Ruckus" PS250
Paint shaker
Post by Paint shaker » Fri Sep 06, 2019 4:16 pm
Thanks for the info so far! One of the reasons I bought this bike was the knowledge found here and the willingness to share it!!
I replaced the pet cock in 2014 I believe. I recently had the tank off while repainting. Tapped everything off. Perhaps moving the tank around and it being upside down caused some loose stuff to move around inside the tank? Will pull the pet cock and check that too.
The plugs seem to indicate it is running rich (dark/black).
Paint shaker
Post by Paint shaker » Fri Sep 06, 2019 4:17 pm
Not sure I want to get into pulling the carbs apart. I am just a shade tree/ simple parts replacer type mechanic... :cheers:
Post by wooden nickel » Fri Sep 06, 2019 6:33 pm
Laird,
If it is running rich but will still run at higher speeds, I suspect dirt holding the needle valve slightly off the seat. It is an easy fix. Lay down so you can see the bottom of the carb. Pull the float bowl, Hold the floats with one hand and pull the hinge pin with the other. Ease the floats down and the needle valve should come with it. Clean the needle valve and seat and turn the petcock to Prime lone enough to flush it. Reassemble, just be careful easing the floats and attached needle valve up into place.
Post by stagewex » Fri Sep 06, 2019 8:13 pm
“I am just a shade tree/ simple parts replacer type mechanic”
Me too. These beasts will eventually make you do things you never thought you were capable of.
Post by jeffsaline » Fri Sep 06, 2019 9:23 pm
My guess is the left carb pilot jet is restricted. Easy fix since that carb is hanging out where you can easily get to the bottom of it.
All you have to do is drop the float bowl. Then remove the pilot jet and inspect first and then clean. Replace the pilot jet and reinstall the float bowl. Probably take you 15 minutes the first time and 3 minutes after that.
Paint shaker
Post by Paint shaker » Sat Sep 07, 2019 4:03 pm
Thanks for more great info. May attempt to follow Wooden Nickle's and Jeff's advice soon! Also no "prime" for the petcock as it has been swapped out for, I believe, a Suzuki one; Off, On and Reserve.
Post by Msblu79 » Mon Sep 09, 2019 7:49 am
Make sure the port on the left carb that use to supply vacuum to the original petcock has been plugged off. If the plug missing or loose it will have a vacuum leak there that can cause issues.
2010 Black Patrol 92,000km's
Paint shaker
Post by Paint shaker » Mon Sep 09, 2019 6:34 pm
Update; New plugs, drained both carb bowls, cleaned left carb bowl, checked the vacuum cap (the vacuum petcock has long since been replaced). Test rode and runs normal.
Side note- The electric start had not been working for sometime now. At CRAP, we determined it was probably a relay. Finally got around to getting a new relay and the starter works again!!
Thank you for all the help and suggestions!! :clap:
Post by Mr Wazzock » Mon Sep 09, 2019 6:42 pm
