Compression 110/120
Marco
Compression 110/120
Post by Marco » Tue Aug 27, 2019 7:13 pm
Right cylinder tests 110 and left tests 120. Does the difference matter much?
Is that compression reasonably healthy?
The valves were adjusted prior to testing.
2012 Gear Up "Anichka"
19,000 Km
"My mother never breast fed me, she told me she only liked me as a friend."
Rodney Dangerfield
Re: Compression 110/120
Post by Lokiboy » Tue Aug 27, 2019 7:16 pm
Within 10% is considered ok
Post by RC20 » Tue Aug 27, 2019 9:33 pm
Was the test done when the engine was on the hot to warm side?
Seems about 20 lbs low on the 120 side. The side to side difference ok, but then that is more of a split.
Seems 140 is more normal. You might squire some oil in the cylinders and see what that does.
I don't have Ural data but the R80 good was 130 psi, marginal was 108. You look to be at marginal on one and a bit low on the other.
Lots of miles would have a bearing
Post by Lokiboy » Tue Aug 27, 2019 10:12 pm
120 is good for a 7 year old rig. I should know, that’s about what mine is.
Post by Desantnik-VDV » Tue Aug 27, 2019 11:42 pm
Yeah, old worn out Urals are more loose.
The rest is just a History:
2014 Ural M70
2002 Ural Barberian Classic
2003 Honda Shadow ACE
Post by RC20 » Wed Aug 28, 2019 1:15 pm
Actual reports are worth far more than the listed data.
Post by harryball » Wed Aug 28, 2019 4:54 pm
My 2008 Tourist ran 120/115
My 2010 Patrol ran 125/110
I think what you are seeing is normal.
I have not checked my 2017 rigs, but from what I know I should see 140+ on those. I did try to check them, but my gauge is broken, gives 60psi no matter what it sees. I mean, I only dropped it, twice, then went to pick it up the second time and kicked it across the shop into a lift pylon. :? Was an off day.
