Flywheel stripped
gsim
Flywheel stripped
Post by gsim » Thu Aug 22, 2019 8:06 pm
I've got a problem, went to pull the flywheel in my Gaucho and the threads and stripped. I can get bolts to go in but there really isn't anything there too grab. Any ideas on how to remove it. On a side note the crankshaft is bad so I need to replace it. I'm up for ideas on this one. Thanks y'all.
2013 Ural Gaucho Rambler
1974 HD Ironhead Sportster "Mr Bones"
1977 Honda CB 750 SS
Former Rides:
2014 Blue Ural Patrol "Laika"
1998 HD FXDL "The Lowrider"
Re: Flywheel stripped
Post by Albuquralque » Thu Aug 22, 2019 8:36 pm
I used a three-jaw puller putting the legs of the puller through the large rounds holes in the flywheel.
You dont actually pull of the flywheel with the puller. Put the puller on and turn it in and put pressure on the flywheel. Now smack the flywheel with a hammer. It should pop off.
gsim
Post by gsim » Thu Aug 22, 2019 9:20 pm
Is there a sweet spot for the hammering on the flywheel? Heat help with the process? It looks like there is the same type of thread material around the crankshaft that was in the the clutch screws. I'll try the 3 jaw puller tomorrow.
Former Rides:
Post by Albuquralque » Thu Aug 22, 2019 10:19 pm
Shouldnt need heat, but it will help if you want to use it. I usually smack it around the outside edge of the flywheel.
Post by jaybird » Fri Aug 23, 2019 12:24 am
I prefer to strike directly on the end of the puller pressure screw, they're made to hit there and less chance of damaging the engine case or flywheel. It shouldn't take a lot of force from the puller.
Post by Snakeoil » Fri Aug 23, 2019 1:46 pm
+1 :thumbsup:
gsim
Post by gsim » Fri Aug 23, 2019 5:29 pm
Three-jaw puller and hammer 🔨 tapping for the win. Thanks for the help. The jar puller is definitely tricky to get in there though.
Former Rides:
Post by Snakeoil » Fri Aug 23, 2019 6:28 pm
You could always tap out the holes to the next UNC or UNF size, whichever is closest to the original thread.
gsim
Post by gsim » Fri Aug 23, 2019 6:38 pm
That's the plan now that it's off.
Former Rides:
Post by jeffsaline » Fri Aug 23, 2019 9:54 pm
Might be worth keeping the threads metric. A heli-coil could be a good permanent fix. It would be really easy to do well with the flywheel off.
