Embarrassing update: cylinder hiss
Re: Rt cylinder hiss
Post by Desantnik-VDV » Wed Aug 14, 2019 1:52 am
Won't thee be oil leak/wet spots to look for as an indicator if the engine case and all surrounding is clean?
The rest is just a History:
2014 Ural M70
2002 Ural Barberian Classic
2003 Honda Shadow ACE
Post by Lokiboy » Wed Aug 14, 2019 6:31 am
It’s good to have fresh eyes. You’re right. As the saying goes “can’t see the forest for the trees”
Re: Embarrassing update: cylinder hiss
Post by Lokiboy » Thu Aug 15, 2019 4:27 pm
Update: Thanks for all the really good suggestions. I even called ski at Tri Quest and he was leaning towards a piston ring, from when I installed new ones a few months ago, was caught in the piston channel and not decompressing, thus allowing blowback.
As it turns out, when I did a major service and again when I was trouble shooting I incorrectly placed the washer on the stud for the valve cover. Apparently, both times the washer came off and was wedged between the wall and the stud nut. Tomcatfixer was in town and after a compression test and a leak test all seemed ok. He suggested we tip the rig on its side so he could better pinpoint the sound. Eureka! That’s when TCF saw the washer out of place.
I can’t count the number of times I’ve removed and replaced the valve cover and now on two consecutive times I do it incorrectly.
Again, thanks everyone for you suggestions. Am I ever embarrassed by such a rookie move.
Post by Mr Wazzock » Thu Aug 15, 2019 4:34 pm
Post by Tomcatfixer » Thu Aug 15, 2019 4:45 pm
That sound was remarkably difficult to pinpoint; it appeared to come from multiple directions, when you stick your head down between the tub and the bike. It was only when you lift the tub and put your head underneath that it became easier to pinpoint the source.
Post by Tomcatfixer » Thu Aug 15, 2019 4:49 pm
Regrettably, I did not capture an image of the wayward washer sandwich sideways between the valve cover and the valve cover retaining nut. However, I did snap this pic of Erika, Lokiboy's stethoscope, my leak down tester, and Lokiboy's calves. :D
Post by Desantnik-VDV » Thu Aug 15, 2019 5:08 pm
Great diagnostic efforts Dr. Lokiboy & Dr. Tomcatfixer!
Good to have another knowledgeable pair of eyes and ears locally who can ride with and come for rescue.
One more troubleshooting job done for the whole Ural community. Someone must create a Ural troubleshooting encyclopedia. This forum is already a big asset for the foilhead freunds.
2014 Ural M70
Post by Snakeoil » Fri Aug 16, 2019 7:14 pm
Given all the background noise on a Ural, finding or even hearing a hiss has to be a challenge. I suspect Chad might be used to finding tiny noises in loud environments, though.
Post by Tomcatfixer » Fri Aug 16, 2019 7:37 pm
Ha! Hardly. I'll share with you that one of my Veterans' Administration disability claims is for tinnitus. 26 years working in close proximity to turbojet and turbofan engines, and now my ears ring constantly. And that's DESPITE wearing hearing protection at work!
Post by RC20 » Fri Aug 16, 2019 9:13 pm
Other than non military, same issue. Around engines a lot and alwyas ear protection and since 40 or so, plugs and muffs.
Going through the process as another mechanic pointed out how bad his ear were despite both, I realized I had gotten used to it.
I figure 60% loss in one ear and the Tinitus and 40% in the other.
