Fuzzy Oil Drain Plugs
Re: Fuzzy Oil Drain Plugs
Post by Snakeoil » Fri Aug 02, 2019 8:15 pm
Yeah, I think the same but different is a good way to describe it. I'll bet the same thing is experienced in the winter months. I noticed a difference in shifting when I ran the bike late into the winter before the first snow came.
My bike is still leak free with the Sta-Lube versus the "freu freu" oil. I always used to laugh at the oil thread where folks warned that syn oils will make your engine leak. Well, it certainly would appear that it made my tranny leak.
That last quart of Royal Purple will be my last encounter with the "freu freu" oils. Not that there's anything wrong with that. :wink:
Post by tgtrotter » Sat Aug 03, 2019 3:27 am
jaybird wrote:
Fri Aug 02, 2019 5:40 pm
Fri Jul 26, 2019 11:16 am
jaybird wrote:
Fri Jul 26, 2019 11:12 am
Rob, how do you find the 75W90 compares to the 20W50 shifting wise?
I'm curious about this as well. 🤔
I decided to arrive at my own conclusions.
Since my Retro was due for oil changes anyway, I decided to try a transmission full of GL 85/140, none of that red or purple “Freu freu”oil, but good old DinoWally Blue :lol:
So far I’ve put 200kilos on the rig today, the best I can describe the shifting is, the same but different, it still clunks into gear, but the clunks are “softer”, the transmission may be a bit quieter as well.
I’d say, give it a try, it’s only a quart of oil.
+1. For a quart of oil, yes. Don't like it, then change it out. Try it for 2500 kms., probly hurt nuthin' , my guess.
Post by jaybird » Sat Aug 03, 2019 9:42 am
I wound up doing around 300Kilos running errands yesterday, I wrote the above while sitting in the diner having a bite to eat. It was a mixture of distance and stop/go, the difference was favorable but nothing to get excited about.
I think it would be worthwhile to try one of the premium oils that Rob/SnakeOil mentions above.
Post by Snakeoil » Sun Aug 04, 2019 7:54 pm
My tranny still leaks, but I don't think it is oil type related. The reverse shifter seal is the cuprit. I replaced it a few years ago. It's that damn oddball size 25x11.5x7mm. I revived an old thread I started last year where I asked for the size since I could not read the size on my seal with the lever in place.
I'm going to try a 25x11x7 seal which I will source tomorrow. It's not a common size. But BDI lists a couple in that size. I'm going to try Kaman since they have a facility where I currently am. Otherwise, the bike seems to be dry as a popcorn phardt since I w@$#ed it down last week. Looks like I'm going to have to lift the hack up and set it on blocks so I can clean out the seal bore before putting in the new seal. Want to coat the OD with Hylomar to assure no leaks around the OD.
Getting back to shifting. When the bike is cold, it shifts without grinding much better than when warm. So, I'm thinking of bumping up the tranny oil to an 80W145. The theory is the thicker oil slows the tranny down quicker for cleaner shifts. It will have to be a GL5, but I don't think that's an issue. Not aware of any yellow metal parts in the Ural tranny.
Post by Snakeoil » Mon Aug 19, 2019 7:35 pm
Closing the loop on this one, too. The little gooseneck I installed into the tranny vent plug seems to have done the job. Bone dry to the touch after several rides.
Today, installed a 0.5mm smaller seal on the reverse shifter shaft and changed out the 80W90 oil for 80W140 oil. Will see if shifting changed (doubtful) and if the leak out the reverse shaft seal is fixed.
By the way, the oil I took out which was only a few weeks old, look like the day I put it into the tranny. I could have put it right back in but never wiped out the drain pan.
Post by Tomcatfixer » Mon Aug 19, 2019 8:20 pm
I'm currently running 85W-140 gear oil in my Patrol and I can't tell the difference between it and the 20W-50 motor oil I was previously using.
Post by jaybird » Mon Aug 19, 2019 8:26 pm
After about 1000 Kilometers I’m going with no discernible difference, although for S&G I might try one of the fancy red or purple oils when it comes time for the next change just to see what I’m missing.
Post by Snakeoil » Tue Aug 20, 2019 9:12 am
The difference between motoroil and gear oil are the additives that prevent shear and the EP additives that help keep some oil between the active faces of gear teeth. I was hoping that a slightly heavier viscosity gear oil would slow down the tranny during shifting to make them smoother.
Another side note here. I noticed something that I think contributed to my reverse shaft leak. I did not look closely, because I wanted to get the job finished and eat dinner. But what I noticed was there the pocket where the seal goes does not appear to have an oil return port at the bottom. So, oil that does get into the pocket by travelling along the shaft cannot return to the tranny and is trapped in the lower half of the pocket. I need to revisit the photos that Chad provided to see if I can drill a small return port if I have to replace this seal again. I've not read of others having an issue with this seal leaking. But it may only be an issue for older, pre-750 trannies. Guess we'll see over time. I did buy two seals just in case.
Post by windmill » Wed Aug 21, 2019 11:16 pm
The only oil I've noticed any difference with was Redline heavy duty shockproof.......because it's 75w250.
Post by Msblu79 » Thu Aug 22, 2019 1:13 pm
Perhaps the bore that the seal sits in is slightly oversize or out of round enough for oil to work itself around the outside of the seal and leak. Some one else here had a block that had a passage that wasn't drilled thru and had several bearing failures until they found out why, it may be possible that the drain hole did not get drilled at the factory. Try putting some sealer around the outside of the seal, if you have it out again, and press it back in and see if it helps. :)
2010 Black Patrol 92,000km's
Post by Snakeoil » Thu Aug 22, 2019 6:47 pm
Yeah, that's SOP for me. I used Motoseal on the last seal and Hylomar on this one. I had already confirmed it was seeping between the shaft and the seal and not the OD of the seal and the case.
Appreciate the suggestion just the same.
Post by tgtrotter » Wed Aug 28, 2019 3:20 am
After watching Rauls video from this topic
viewtopic.php?f=5&t=54738
I thought to myself he was forcing his shifts somewhat. However I recently been shifting my 07 Patrol a little more hurried than my usual one and two count shift and find it "feels" tighter. Just a perception imo. Running 15/40 Delo and have no complaints other than what has been said about clunky and loose Ural shifting and gear boxes.
Oh and by the way Rob, I concur. Any amount of fuzz or metallic sheen is cause for thought. I remember the oil in my my old Cummins 350 at 750k looking pretty shiny. Recently I did the initial 20 hr change on a new Onan QR Generator. no evidence of fuzz but the oil was darker than the replacement and did have a very noticeable shiny metallic sheen. I didn't do your magnet idea. Made a note in my book to see if oil next change looks same or better than break-in. If so investigate further.
Thanks for your post.
