Rear wheel bearings
Fran
Rear wheel bearings
Post by Fran » Wed Jul 17, 2019 4:11 pm
This is Fran from the Big Trip. I need some help we have a 16 GU and the rear wheel bearings are bad. A couple of questions could I remove the wheel bearings from the spare wheel and use them? What size are the bearings maybe I can get some here. I can have some shipped from Ural Miami but it would be a lot easier to get them here. Has any one changed these out and what is the procedure, do I need any special tools? Any and all advice is welcome and appreciated.
Re: Rear wheel bearings
Post by Albuquralque » Wed Jul 17, 2019 4:44 pm
SKF 6204-2RSH
Pretty easily sourced bearing.
What makes you think your bearings are bad?
Fran
Post by Fran » Wed Jul 17, 2019 7:05 pm
Thanks Albuquerque. Just realized the spare is for the rear thought it was for other 2. I will start hunting for the bearings tomorrow after I install the spare. To answer the bearing question, experience, I have owned a lot of worn out machinery, wheel wobble and cracking sound are typical clues. I really appreciate your help. Are they hard to change?
Post by Albuquralque » Wed Jul 17, 2019 7:09 pm
Wheel bearings are all the same in all the wheels.
Sorry never changed the sealed bearings in a Ural wheel.
Post by jaybird » Wed Jul 17, 2019 7:50 pm
They're not hard to change, unless they're really corroded into the hub, you should be able to change them out on the side of the road, with the tools provided in your tool kit, just make sure you put everything back together in the same order/orientation.
There's probably a video floating around somewhere if you start googling, or try myural, they're only slightly different than changing the old tapered greasable type.
Where is "Here"?
BillyG
Thread Killer
Thread Killer
Post by BillyG » Wed Jul 17, 2019 8:31 pm
Are you sure the wobbling and cracking isn’t loose spokes? Pusher spokes can loosen quickly...just an alternative thought.
Bill Glaser
2002 Ural Patrol "CYKA"
Post by gobium » Wed Jul 17, 2019 8:41 pm
Very easy to do.
No special tool needed may be a hammer
I shoot you a video if time permited
Post by gobium » Wed Jul 17, 2019 8:54 pm
Look at the spoke nibbles for cracks
Post by jaybird » Wed Jul 17, 2019 9:52 pm
I agree.
I've had pusher spokes loosen many times, but I've only had bearings disintegrate once, they were the older greasable type, and I'm sure it was caused from my benign neglect :lol:
Manscout
Post by Manscout » Thu Jul 18, 2019 11:11 am
If it is the bearings and they are the sealed type, there is not much too it.
2011 Ural Patrol
Gillette, Wy
Instagram: manscoutwyo
Fran
Post by Fran » Sun Jul 21, 2019 5:13 pm
Here is the situation as of now. I swapped out the rear wheel for the spare. (In my last post on the big trip I called the spare a waste and just extra weight. How wrong was I.) That went fine the disc came off fairly easily and it all went back on the bike without problems. Are they serious about temporary use only or is it like the gas cans not being for gas? 80k max not an issue as that is our max normally.
I got one bearing out of the original wheel reasonably easily but could not budge the bolts on the splined flange. Luckily there is a KTM dealer nearby where they got the allen bolts off. Much beating with an impact driver finally paid off. The other bearing is now out and I decided to have KTM press the new bearings in. If they were not so convenient I would do it myself using the old bearing and the dreaded hammer but why risk more problems. I also got the bearings from them and a couple of spares. The owner has raced in the Dakar 4 times and when I let him drive Pferdi, muy dificil was his comment.
The cause is I think grease and dirt getting in and clogging the bearings I will have to add cleaning this in the future every 20,000k is my guess.
I have some parts coming from the US including the dust seal and as soon as I get that I will put the original wheel back on.
Thanks to every one for the advice and help you guys really have our back.
