Final Drive Nuts (2WD)
glacoste
Post by glacoste » Mon Jul 15, 2019 9:44 am
Wanted to replace the four nuts that mount the FD to the swing arm. Parts call for M10x1.25-6H.
All I can find are M10X1.5 from BellMetric.com. Would these work?
Thanks
2013 Gear-up
Re: Final Drive Nuts (2WD)
Post by jaybird » Mon Jul 15, 2019 10:29 am
No, they need to be the same thread pitch as the stud.
glacoste
Post by glacoste » Mon Jul 15, 2019 10:36 am
2013 Gear-up
Post by Lokiboy » Mon Jul 15, 2019 10:39 am
ACE or True Value carry the nut size you need
90,000 km and counting
glacoste
Post by glacoste » Mon Jul 15, 2019 11:38 am
2013 Gear-up
FlyingMonkees
Post by FlyingMonkees » Mon Jul 15, 2019 7:05 pm
2014 Camo Gear Up (Светлана)
2013 Black Retro Solo (Татьяна)
2010 Black Solo T
2010 Rust Camo Gear Up (Ольга)
2005 Black Wolf (Наташа)
2014 Harley Ultra Limited
PA-31
Post by Tomcatfixer » Mon Jul 15, 2019 10:05 pm
While you're ordering from Belmetric, order one of these Nordlock lock-washers for each fastener.
https://www.belmetric.com/nordlock-w@$# ... 4evkto3ba0
I had the Nyloc nuts on my 2015 cT's final drive work their way loose, but never had that problem again once the Nordlocks were installed. I even used 'em on my 2001 Patrol's cylinder base studs. They're fantastic!
Post by windmill » Mon Jul 15, 2019 10:36 pm
Van turned me on to Fuji nuts, and are what I used for my M70.
https://www.belmetric.com/metric-fuji-n ... 4evkto3ba0
glacoste
Post by glacoste » Tue Jul 16, 2019 4:27 am
Bellmetric did have the right size, but there not as tall as the original nut. Does that matter?
2013 Gear-up
Lee Pape
Post by Lee Pape » Tue Jul 16, 2019 8:35 am
You need at least 3 full threads of engagement to achieve maximum strength. After 3 full threads it doesn't make much difference if it is 4 threads or 100 threads. I speak from being a journeyman tool and die maker for 40 years.
Post by windmill » Tue Jul 16, 2019 9:52 am
On my M70 a Fuji nut with plain washer is Ideal, leaving a couple of threads exposed. The studs are a bit short for the OE nylock and nordlock combination.
Post by Tomcatfixer » Tue Jul 16, 2019 10:39 am
A bit, but the combination has worked out famously for me.
n3303j
Post by n3303j » Thu Jul 18, 2019 1:38 pm
You want at least 1.5 times the diameter of the threaded fastener engaged in the threads if possible. This engagement will mean the stud will fail before the threads strip.
Just a FWIW from another old die maker.
