Rear Brakes
backpacks_got_jets
Rear Brakes
Post by backpacks_got_jets » Sat Jul 13, 2019 10:54 pm
So.
2007 Tourist
Brand new ural rider (been on it a few months) and i have to replace my rear brakes.
I'm pretty good with straightforward repairs/maintenance but I'm not really a car/bike guy or gearhead and i need a little guidance.
Before I buy brakes is there anything silly I should know that i don't yet know about them? Any preferred Brakes? Links to what you guys think I should grab?
Thanks guys!
Joe Civitello
2007 Ural Tourist
My dog is cooler than your dog.
Re: Rear Brakes
Post by S 854 » Sun Jul 14, 2019 12:12 am
Ural rear brakes are a specific part... available from your friendly neighborhood (or internet) dealer...
Once you get them, do a search on “chalking the shoes”... you’ll probably need to “adjust” the fit to yer drum... a bit time consuming but not difficult at all...
Re: Rear Brakes
Post by Albuquralque » Sun Jul 14, 2019 8:47 am
Re: Rear Brakes
Post by Albuquralque » Sun Jul 14, 2019 8:49 am
Re: Rear Brakes
Post by Albuquralque » Sun Jul 14, 2019 8:52 am
How many kms do you have on the rig? Why do you think you need to replace the rear shoes?
The reason I ask is because Ural rear drum brake shoes last a very long time.
backpacks_got_jets
Re: Rear Brakes
Post by backpacks_got_jets » Sun Jul 14, 2019 6:15 pm
theres a bit over 20k Km on the bike. I have to depress the pedal too far and too hard for effective braking and they're squeaking. My only real reference point is from cars so I was just assuming I'd change them out and get a new baseline since it's not prohibitively expensive and its a new-to-me bike that I want to make sure doesn't randomly explode on me.
Joe Civitello
2007 Ural Tourist
ReCycled
Re: Rear Brakes
Post by ReCycled » Sun Jul 14, 2019 6:39 pm
Watch the videos. Clean and adjust will go a long way, you'll have to go through the process with new shoes anyway. Doubtful they're worn out in 20k.
David B.
'07 Ural Twourist
Re: Rear Brakes
Post by Albuquralque » Sun Jul 14, 2019 7:01 pm
20 k is nothing for ural drum brakes. Adjust them properly and ride on.
backpacks_got_jets
Re: Rear Brakes
Post by backpacks_got_jets » Sun Jul 14, 2019 7:42 pm
Rock on.
I'll adjust and see how they roll. Thanks for the advice
Joe Civitello
2007 Ural Tourist
Re: Rear Brakes
Post by jaybird » Sun Jul 14, 2019 7:43 pm
The squeak may be a broken return spring, pull the wheel, it's an easy job that you should be familiar/comfortable with before you need to do it on the side of the road.
Once you pull the wheel, you can check the condition of the shoes, springs, etc, clean and adjust, then you'll know what you have.
Re: Rear Brakes
Post by Lokiboy » Sun Jul 14, 2019 8:49 pm
You will always have to press down long and hard to get them to work.
Just reside yourself to the fact that nearly all your braking is from the front. Folks spend a lot of time getting it just right for the pusher. I drive defensively and never crowd the vehicle in front.
Quick way to determine if the adjustment nut is set properly is to ride for about 5 miles. Put you hand on the pusher’s hub. Warm is good. Hot or cold adjust the nut one complete rotation in the appropriate direction and try again later.
