1998 Ural Deco Classic voltage regulator
BigVic64
Post by BigVic64 » Sun Jul 07, 2019 3:36 pm
Greetings,
This should be a pretty easy question for you.
I'm replacing the voltage regulator on my 1998 Ural Deco. I'm using a Hitachi T107-22. The diagram shows one tab to ground, one to DF on the alternator/starter and one to the solenoid. The tabs on the regulator are marked D-, D+ and DF. I'm guessing DF goes to DF but which tab is alternator/starter and which is solenoid?
Thank you for your help.
