Cylinder Head Temperature Differences
brookscooper
Post by brookscooper » Tue Jul 02, 2019 1:47 pm
So, after my adventure a few years ago where I soft seized the left piston in the jug, I decided to add a dual CHT gauge to the bike so I'd have warning if I was overheating so I could stop and cool before doing damage.
First ride of any length was today. The left head consistently reads 20 - 25C cooler than the right.
If this were your rig, would that concern you? What, if anything would it prompt you to do?
Carbs are balanced, valves set correctly, carbs have same jets, same needle positions, etc. Timing is correct. Engine runs great, smooth (for a Ural) and strong. So, no subjective signs of problems.
2004 Black / Chrome Tourist
Portland, OR
Donbmw
Re: Cylinder Head Temperature Differences
Post by Donbmw » Tue Jul 02, 2019 2:06 pm
On my rig the RH is about that much cooler thane the LH. From other post here the RH is normally the cooler side.
Don
Wanderrad
Post by Wanderrad » Tue Jul 02, 2019 2:25 pm
Completely normal.
Edit: sorry, I didn’t do the math right. 20-25 C does seem like a bit much. Mine runs about 10C difference at 60 MPH and they quickly balance when I come to a stop.
-Scot
Post by Peter Pan » Tue Jul 02, 2019 3:42 pm
Double check wih Infrared thermal gun, might be the sensors are crossed over. My Sophie too used to have the left side always hotter, before I took off the vacuum hose from the gasoline valve. Once with manual gas cock both cylinder heads use to stay within 5ºC (correctly called 5K as Kelvin). Typically 115-185ºC depending on weather and climbs.
Sophie Travelair = Patrol 2013 =>43.388km+nacked :shock: :pot:
Engine: 1.43.388km :gahhh:
Post by chaos2 » Tue Jul 02, 2019 9:31 pm
the chair side usually runs cooler because of the air funneling by the head. Mine RH cylinder usually runs about 20F cooler, 20C seems a bit much.
brookscooper
Post by brookscooper » Wed Jul 03, 2019 10:26 am
So, this engine takes a looooonng time to fully come up to temp. The ride home yesterday had a lot more uphill travel and thus, more heat generated. By the end of the ride the two sides were nearly Identical. As a toy, the CHT is fun, for longer rides or ones really involving bills it will be very useful.
Both sides stabilized at right around 175C and varied only slightly with changes in load. I’ll always wonder how hot the rig was when I killed the left piston and jug. Ah well, she’s back on the road and running well.
Portland, OR
