Page 2 of 2
Re: Had to ride home in 1 or 2 gear
Posted: Fri Jul 12, 2019 10:52 pm
by africalight
Ok so got the new parts from Terry. Watched the videos on how to get the rod to seat into the square hole. Think I have the rod seated and inserted the bearing. Put the slider in and it doesn’t seem like it is going on far enough. It’s so tight that I cannot get the lever back on without removing the wire. Wire off and no way am I going to get it back onto the lever. Any help would be appreciated. Thanks
Posted: Sun Jul 14, 2019 7:59 pm
by Waffl6
The easiest way to do this is to remove the clutch cable and put it back on...you can give it a ton of slack with the adjustment nuts.
Posted: Thu Jul 25, 2019 1:07 am
by Waffl6
Any updates to this? Curious to see if you have gotten your rig back on the road.
I have not. Big surprise there... :roll:
