Had to ride home in 1 or 2 gear
africalight
Re: Had to ride home in 1 or 2 gear
Post by africalight » Fri Jul 12, 2019 10:52 pm
Ok so got the new parts from Terry. Watched the videos on how to get the rod to seat into the square hole. Think I have the rod seated and inserted the bearing. Put the slider in and it doesn’t seem like it is going on far enough. It’s so tight that I cannot get the lever back on without removing the wire. Wire off and no way am I going to get it back onto the lever. Any help would be appreciated. Thanks
2006 Patrol-Totally Rebuilt Engine and going through break in again
Waffl6
Post by Waffl6 » Sun Jul 14, 2019 7:59 pm
The easiest way to do this is to remove the clutch cable and put it back on...you can give it a ton of slack with the adjustment nuts.
Past bikes: 1994 Katana 600
Fairfax Virginia
Waffl6
Post by Waffl6 » Thu Jul 25, 2019 1:07 am
Any updates to this? Curious to see if you have gotten your rig back on the road.
I have not. Big surprise there... :roll:
Fairfax Virginia
