Carb missing parts?
glacoste
Carb missing parts?
Post by glacoste » Thu Jun 27, 2019 8:09 am
Yesterday I posted problems with my right carb. Decided to follow directions in myural.com to disassemble for a cleaning. Noticed that after removing the main jet there was not a needle jet. Also removed the diaphragm needle which had 3 shim/washers.
I am assume that the 3 shim/washers on the diaphragm needle don't need to be there. Don't know about the needle jet. Doesn't look like its in there.
My other carb is newer. I took a look to see if it had a needle jet. Couldn't see one.
Any input would be greatly appreciated.... Thanks!
2013 Gear-up
Re: Carb missing parts?
Post by gobium » Thu Jun 27, 2019 8:29 am
Shims are OP add on, also check to see if slide been drilled.
I dont see silver needle seat/holder
cateyetech
Post by cateyetech » Thu Jun 27, 2019 8:37 am
Hey g
look in the carb body where the needle goes
it's stainless steel & you may have to tap it out
:foilhead:
Charlie ╭∩╮(-_-)╭∩╮
2003 Gear-Up Ромашка Мзй
2000 Patrol Teh Урал
glacoste
Post by glacoste » Thu Jun 27, 2019 11:12 am
Found it!
Cleaned carb and it starts again!
thanks for the input.
2013 Gear-up
