Stumper clutch issue
Subsnowden
Post by Subsnowden » Sat Jun 01, 2019 2:12 pm
I’m back again with another breakdown adventure. Last weekend my clutch cable broke at the lever end during a relaxing shift to 2nd. I turned the bike off and coasted off to the side of the road which fortunately happened to be motorcycle only parking at the vintage bike show I was attending. So of course many people witnessed the Ural doing what it does best...breaking. No problem, I thought, I have a spare clutch cable with me. I’ll just run back to camp, grab it, swap it, back in business. Right?
Wrong. The (new) clutch cable was way too tight. It was a real struggle to get it into the lever and get everything reassembled. All the adjustments were at their absolute minimum and the clutch lever feels like a midget it pulling the other end. Now here’s the kicker, the clutch is basically always engaged. I can shift gears and go to reverse and neutral with the clutch lever fully released. I thought maybe when the cable snapped that my clutch shot back with such force it knocked my clutch rod square peg out of the square hole. Nope. I’m able to get it lined up and locked in just fine. I have removed the clutch twice now and the transmission 3 times and every time it seems like I have “too much” clutch rod. The thrust bearing shaft is seating on the clutch rod properly, the plunger is resting on the thrust bearing properly. The plunger is sticking out about 1/4 inch from the back of the transmission using my eyecrometer. The clutch arm isn’t bent, the cable is the exact same length as my old one. I did recently put a new clutch and rebuilt transmission in about 6 or 700 miles ago and everything seemed to be working well during that time. I have called Crawford, Holopaw, and Heindl and they are all at a loss. I also understand it’s hard to diagnose over the phone.
Any ideas are welcome. I haven’t listed everything I’ve tried or verified because I’ve already typed enough so I’ll cross that bridge as suggestions emerge.
Jon
Nomad
2015 Ural Gear Up
Re: Stumper clutch issue
Post by VWK75S » Sun Jun 02, 2019 6:17 am
Pictures of each point might help.
2009 GearUp 145,000kms
Post by Albuquralque » Sun Jun 02, 2019 7:50 am
Do you know the part number of both the cables?
Post by stagewex » Sun Jun 02, 2019 8:51 am
I changed the original clutch-cable on my 2007 a few years when I ran out of adjustment. It stretched rather than broke like in your situation. I ordered from Terry and after taking off the old one it was way, way shorter than the old one when laid out side-by-side. Now I realize that a cable does stretch to a point but not like this including the protective sheath. I called Terry to ask him if he perhaps sent me the wrong part. He said that Ural had changed vendors and this was/is the only cable available now, same exact part number but clearly not the same physical cable. What to do? I went to the local dealer who happened to have a 2015 on the showroom floor and observed that they navigated the clutch-cable a different way around the frame than originally. Took a bunch of pictures with my phone and duplicated at home. THAT made the difference and I was motoring again after a few stop-and-go adjustments around the block. Mentioning this because of the possibility you might have made a different turn in your reinstallation there isn't a lot of forgiveness depending on what "stock" clutch cable you may have as a spare.
It also sounds like your cable broke from something mechanical and not wear if I'm reading this right. 2015 is certainly not a proper service life.
The de-compression cable on my '91 xr250 broke after a hard fall in the woods a day before the JDH a few weeks ago. Ironically after setting it by hand (with no cable) it starts better now than with the cable:
It's a "leg-saver" (kick-start only) but really, without it... it starts better.
After 28 years she finally gave-up-the-ghost. No complaints.
Post by jaybird » Sun Jun 02, 2019 11:43 am
The clutch cable for the Retro/M70 is a longer cable than the GearUp Et al, it was my understanding that that cable is the new replacement for all models.
Maybe one of the dealers can confirm this.
I second what Mike Wex said about the routing, you may just need to take a different path.
Subsnowden
Post by Subsnowden » Sun Jun 02, 2019 7:04 pm
I don’t know the part number for both cables but they were the exact same cables when comparing them a couple months ago. Routing has made zero difference. It was routed appropriately to begin with and any variations have caused no change. I also agree that something mechanical happened but I can’t find anything broken, missing, out of alignment, etc. Transmission and clutch are coming back out tomorrow for another inspection.
I will try to post pics but is a PITA on mobile
Jon
Nomad
2015 Ural Gear Up
Subsnowden
Post by Subsnowden » Thu Jun 06, 2019 8:11 pm
Anyone happen to know what the length of a 2015 clutch rod should be?
Jon
Nomad
2015 Ural Gear Up
Subsnowden
Post by Subsnowden » Wed Jun 12, 2019 9:25 am
I have verified my clutch rod length is correct. 5 and 9/10 inches by micrometer. Anyone feel like posting a few pictures of different clutch plungers sticking out of the back of the transmission to compare?
Jon
Nomad
2015 Ural Gear Up
Post by Lokiboy » Wed Jun 12, 2019 11:34 am
To get the clutch cable and parts to fit, yep loosen the adjustment nut above the tranny
Then, unscrew the clutch lever and attach the cable. Now, pivot the lever back in place and insert the screw.
As for the clutch rod, a possibly is that it’s not properly seated in the clutch plate.
Post by Peter Pan » Wed Jun 12, 2019 3:35 pm
square of clutch release needle sitting on top of the spring disc (not resting inside the nest)? Sometimes it is nasty to settle well.
I use a dentist's tweezer as it reaches deep into the clutch push rod opening
Subsnowden
Post by Subsnowden » Wed Jun 12, 2019 4:08 pm
The square end is going in the square hole. 100%.
Jon
Nomad
2015 Ural Gear Up
Post by GHGoodwin » Wed Jun 12, 2019 6:16 pm
Put a plastic straw over the rod. You can insert it and the rotate it until it "drops" into the square hole. Bamboo skewer into center holds rod in place while removing straw.
Subsnowden
Post by Subsnowden » Fri Jun 14, 2019 3:54 pm
Fixed it! I put a shorter clutch rod in and everything is working and feels great. I don’t know why that fixed it but right now I’m just happy it’s working.
And don’t worry everyone. The square peg is in the square hole
Jon
Nomad
2015 Ural Gear Up
