1999 650. Only firing one plug
Adelphia
Re: 1999 650. Only firing one plug
Post by Adelphia » Sat Jul 06, 2019 11:51 pm
jaybird wrote:
Sat Jul 06, 2019 11:39 pm
I am also going to order the wrist pin reamer tool they have listed. I don't know how to use it or exactly what it's for, but I think I might need it to replace the bushings
Even though the kit comes with bushings, if the bushings you have are not worn out, you don't need to replace them.
For me, It's a number of things.
1.) I hate CV carbs. I hate them a lot. I find them exponentially harder to setup. I can take the diaphragms out and put them 3 blocks away when I clean a carb and somehow, some way, they will STILL get carb cleaner on them. Every time without fail. They should all be cast into the sea.
2.) It was originally designed to have the carbs bolted to the head. I'm becoming a big fan of "as intended" in my old age.
3.) I have big dumb feet that hit things
As for those bushings. Are they matched? Do I reuse the old wristpins for wear and matching reasons? That would make my life easier.
Dustin
2019 Yamaha Bolt R-Spec - 1999 Tourist 650 - 1980 Honda CM200T
Post by Mr Wazzock » Sun Jul 07, 2019 5:29 pm
Adelphia wrote:
Sat Jul 06, 2019 5:45 pm
Managed to break a compression ring. It snapped off in my hand while I was filing it so I assume it might have had a foot out the door to begin with. Ordering a new set.
IME piston rings are very brittle. The one and only time I've had to increase the gaps on any, I used a fine grindstone, not a file. Then push it into the bore and measure the gap with a feeler gauge. Remove, repeat ...
URALNUT60
Post by URALNUT60 » Sun Jul 07, 2019 5:47 pm
I broke oil control ring while fileing, they do make a nice tool $60, ugh! As far as wrist pin fitment McMaster Carr 7/8 ball hone 240 grit in a cordless drill $18, makes it a easy job
Adelphia
Post by Adelphia » Sun Jul 07, 2019 10:29 pm
IME piston rings are very brittle. The one and only time I've had to increase the gaps on any, I used a fine grindstone, not a file. Then push it into the bore and measure the gap with a feeler gauge. Remove, repeat …
These are were very tight out of the box. Either at 0 or overbore. I'm using a very fine mini file I've used in the past with great success. The rings are just so gigantic that being brittle is definitely an issue.
Dustin
