Alternator noise, help me get home!!
Cueball
Post by Cueball » Fri May 17, 2019 9:35 pm
After 3900 miles in the southwest us in the last 2 weeks, I'm 308 miles from home in Kilgore, tx with my alternator knocking badly. Any ideas on making the last 308 kiles??
Never rode a sidecar rig until today when I traded one of my bikes for a 2012 patrol. Think I'll learn by the time in turn 70 in july? :D
Re: Alternator noise, help me get home!!
Post by wooden nickel » Fri May 17, 2019 9:59 pm
For 308 miles, I would pull the alternator and go total loss.
Cueball
Post by Cueball » Fri May 17, 2019 10:24 pm
Won't it throw oil out? If not, that's what I'll do. Got another battery with me
Post by Lmo » Fri May 17, 2019 11:28 pm
Might stop by a hardware store and pickup a round electrical outlet cover. Drill a couple of holes and seal with some Gorilla Tape. It only has to last a few hours.
i.e. Image
URAL CT
Post by URAL CT » Sat May 18, 2019 12:56 pm
Just a thought...WWID? Take alternator assembly out, remove alt adapter from alternator, reinstall adapter (if not the part making noise)...go home. If u ain't home yet, good luck. :mrgreen:
CT
2007 Patrol
Plano, TX
Post by Albuquralque » Sat May 18, 2019 1:01 pm
Great suggestion!
Post by Albuquralque » Sat May 18, 2019 1:02 pm
Don't forget to tape up all the electrical connections. Also, if the alternator is disconnected, your e-start won't work.......you'll have to kick start.....then ride it!
robp
Post by robp » Mon May 20, 2019 8:33 am
Clever idea, that!
So Cueball - what happened - didja make it home OK?
Post by Mr Wazzock » Mon May 20, 2019 7:55 pm
It should if you ground the charging light wire. :D
Cueball
Post by Cueball » Mon May 20, 2019 10:34 pm
Unfortunately, it seized up when I tried to get to a parts store Saturday morning. Called geico for a tow, rented a car to drive the final 388 miles home. Drove back today with my jeep and trailer and retrieved it. Haven't tried to diagnose it other than pulling the alternator when it seized and discovering that it w@* still seized sans alternator.
I'm gonna need help , I'm sure.
Post by Albuquralque » Tue May 21, 2019 6:45 am
So can we assume it wasn't your alternator that was knocking?
Cueball
Post by Cueball » Tue May 21, 2019 1:02 pm
I'm not sure. I used my tire iron stethoscope when it was making the noise and the knocking definitely seemed to be coming from the alternator. Maybe it was transferring noise from elsewhere. Haven't had a chance to do anything with it yet (lawn horrible after being gone 3 weeks), any guidance appreciated.
Manscout
Post by Manscout » Tue May 21, 2019 2:59 pm
You will get lot's of suggestions, but I would pull the spark plugs and slowly try to turn it over using the kickstart. Eliminate that it isn't hydro-locked first.
2011 Ural Patrol
Gillette, Wy
Instagram: manscoutwyo
Post by Mr Wazzock » Tue May 21, 2019 5:48 pm
Bum. :(
Cueball
Post by Cueball » Wed May 22, 2019 7:31 pm
Started investigating today. First drained the oil. Drain plug had a good bit of large metal dwarf and the oil had a brass colored metallic sheen.
Pulled valve covers, left one had good amount of what appeared to be aluminum flakes, right one not so much.
Pulled starter to check clutch bolts, but could barely turn flywheel with a screwdriver. Didn't want to break a tooth so I stopped.
Any advice, ideas, or direction much appreciated!!
