Stuff That Works
Re: Stuff That Works
Post by Lokiboy » Fri Jun 14, 2019 6:11 am
Motion Pro’s quick disconnect has worked perfectly and has made removing the fuel tank such a breeze - Not having to drain the tank, not getting fuel all over the place.
Also, Raceway’s Perch Ring set.
http://racewayural.com/product/new-cvk- ... t-pn10289/
Since installed I’ve never had the carburetor come loose from the branch intake connection.
Post by chaos2 » Fri Jun 14, 2019 9:11 am
+1 on the Raceway Carb Perch. That and the 2013 style intake rubbers are 2 of my better Ural improvements.
Post by sKiZo » Fri Jun 14, 2019 1:09 pm
Recently converted to a tank shifter on my 2011. Just prying the shift levers off is frowned upon as you can damage the seals, so I did a little digging and came up with this little guy at the local Advance Auto and tapered the ends on the grinder so they'd fit behind the levers. Worked like a charm, perfect size for tight places, and now a permanent part of the tool kit.
Post by rougaroo » Fri Jun 14, 2019 1:20 pm
+2 on the MotionPro disconnects.
Side discussion, though. I initially mounted mine the way Dave has his routed, but for me the gas line kept cracking at the sharp bend and the line got in the way whenever I had to do anything on the battery. I finally used a longer length of 1/4" gas line and routed it *underneath* the air filter, then put the disconnect on the right side between the air filter and the tank. That makes it lots easier to remove the tank and leaves a lot of clearance on top of the air filter.
bgenest
Post by bgenest » Sat Jun 15, 2019 7:06 am
Rougaroo,
You Have a picture of your install? I need to install the disconnects I bought last year. Thanks.
Bruce
Post by wooden nickel » Sat Jun 15, 2019 8:36 am
When I installed my disconnect, I just made the lines 10 or 12 inches long. Long enough to make an easy 180 degree bend in each of them on top of the air cleaner. When I needed to disconnect, I just pulled the lines to one side, out in the open.
Post by rougaroo » Sun Jun 16, 2019 6:17 pm
You have a picture of your install? I need to install the disconnects I bought last year. Thanks.
Sure.
One side:
The other side:
bgenest
Post by bgenest » Mon Jun 17, 2019 7:20 am
Thanks!
Post by RC20 » Wed Jun 19, 2019 11:00 am
ST100 is good cleaning stuff
I have the Zro Start power pack and its been great to recharge cell phone, light at night and any other device that uses a USB power up and I will get the harness hooked up up for a start issue if that should occur.
Chargers off the Europ plug with and adapter or 120 volt.
MartyL
Benevolent Emperor
Benevolent Emperor
Post by MartyL » Wed Jun 19, 2019 11:47 am
:wink:
1976 Yamaha XS650C
2018 H-D FLHXS
Post by Lokiboy » Wed Jun 19, 2019 11:52 am
MartyL - Thanks for taking it down a few notches :roll:
bratmanxj
Post by bratmanxj » Wed Jun 19, 2019 2:23 pm
:wink: C6D71877-7E51-4DE4-AC16-A8437FA91BAB.png
Only took 7 tries to get this to post!
Adelphia
Post by Adelphia » Thu Jun 20, 2019 1:36 am
Use Mop 'n' Glo on all plastic parts. Even the ones that weren't very shiny to begin with will look great. It has an added benefit of leaving a film on the plastic which helps to keep dirt from adhering. It's a trick I learned as a kid riding quads and found to transfer well to the road world.
Dustin
2019 Yamaha Bolt R-Spec - 1999 Tourist 650 - 1980 Honda CM200T
Post by tgtrotter » Sun Jun 23, 2019 6:51 pm
I watched my neighbor w@$# and detail his bike. Towards the end he finished up his clear plexiglass (plastic) windshield with WD-40. He said to get the last of the bugs off, keeps it clear of swirl scratches and yellowing. Looked good to me at 14 yrs old.
Post by a1930ford » Sun Jun 23, 2019 8:01 pm
STUFF THAT WORKS: A GOOD RAM MOUNT FOR YOUR GOPRO CAMERA. :-)
