Weeping gearbox
xpatriot
Weeping gearbox
Post by xpatriot » Thu Feb 14, 2019 5:00 pm
Hello,
I have a weeping shifter. I assume this means pulling the gearbox, cracking it open and replacing a seal. If anyone wants to make my day by telling me it's far easier than that, they can be my valentine :wub:
Thanks.
1999 650 Tourist "The Moscow Mule" *For Sale*
Manscout
Re: Weeping gearbox
Post by Manscout » Thu Feb 14, 2019 5:10 pm
Where is it weeping from?
2011 Ural Patrol
Gillette, Wy
Instagram: manscoutwyo
xpatriot
Re: Weeping gearbox
Post by xpatriot » Thu Feb 14, 2019 5:17 pm
Where the shifter shaft enters the gearbox.
Re: Weeping gearbox
Post by hotflash44 » Thu Feb 14, 2019 5:41 pm
how about a heavier weight oil. worth a try IMO. :cheers:
Subsnowden
Re: Weeping gearbox
Post by Subsnowden » Thu Feb 14, 2019 5:46 pm
Sounds like a constant oil refresh system...
Jon
Nomad
2015 Ural Gear Up
Re: Weeping gearbox
Post by Tomcatfixer » Thu Feb 14, 2019 7:11 pm
No easy fix. Gotta break it down to China-town.
Re: Weeping gearbox
Post by Tomcatfixer » Thu Feb 14, 2019 7:14 pm
Mark the position of the gear selector tab on the splined shaft before removing it. If you get it wrong, you have to completely disassemble the transmission to reposition it, unlike the newer gearboxes.
Re: Weeping gearbox
Post by jaybird » Thu Feb 14, 2019 7:45 pm
In the short term you could try some "Liquid transmission seal", it can't hurt.
I wonder if you can retrofit the newer shifter and shaft to the older transmission?
Re: Weeping gearbox
Post by Tomcatfixer » Thu Feb 14, 2019 9:00 pm
I'm almost certain that this is possible. I believe the shaft diameters are the same. I can check, if necessary, but not right now.
Re: Weeping gearbox
Post by Wildhorse Cafe » Thu Feb 14, 2019 9:17 pm
Hello,
Thanks.
Read this , 3yrs and still going strong.
viewtopic.php?f=5&t=44301&p=551789&hili ... er#p551789
Donbmw
Re: Weeping gearbox
Post by Donbmw » Thu Feb 14, 2019 10:39 pm
I did this also when I found my shift shaft leaking. I was not leaking for a couple months until I had my transmission replaced because of the wear on the input shaft and clutch splines being stripped.
Don
Re: Weeping gearbox
Post by Wildhorse Cafe » Fri Feb 15, 2019 12:29 pm
In the name of Ural Roberts, heal heal!
Re: Weeping gearbox
Post by jaybird » Fri Feb 15, 2019 12:54 pm
I agree, and no rush for me, the question was somewhat rhetorical and more to benefit the forum/conversation.
I could answer my own question, but to date I haven't had the two vintages of transmission apart at the same time, I do however currently have some older transmissions in pieces, so the next time I take apart a more modern one I plan to try it.
Re: Weeping gearbox
Post by S 854 » Sat Feb 16, 2019 9:49 am
I have a weeping shifter. I assume this means pulling the gearbox, cracking it open and replacing a seal. If anyone wants to make my day...
Try a little Zen...
Play this during disassembly... mentally change “guitar” to “gearbox”... (in my best George Harrison falsetto, “While my gear-box gently wee-EEPS)
...and maybe this might help...
xpatriot
Re: Weeping gearbox
Post by xpatriot » Sat Feb 16, 2019 2:18 pm
Donbmw you have won my heart...I’ll give it a try.
