Engine case cleaning
Re: Engine case cleaning
Post by S 854 » Mon Feb 11, 2019 9:46 am
stagewex wrote:
Sat Feb 09, 2019 10:43 pm
That Green Magic product looks pretty incredible.
Looks like it eats oil, crud and cylinders... be careful!!!
I’m with Dave... no washie for me... I probably have some NorthWet muck on my rig... from when I picked it up... in 2007...
Post by Tomcatfixer » Mon Feb 11, 2019 9:57 am
Kerosene
While I'm a big fan of kerosene because it's an effective solvent that doesn't attack rubber, it doesn't offer the aluminum "brightening" characteristics of the other cleaners mentioned above.
BlueRockCrawler
Post by BlueRockCrawler » Mon Feb 11, 2019 10:17 am
Ah, OK.
2015 Ural Patrol
1993 Suzuki DR 650
2018 Suzuki DR 650
previous Honda's were
1996 750 Magna
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
Post by Wildhorse Cafe » Mon Feb 11, 2019 11:55 am
It's water based and in my experience there was no evidence of corrosive potential. I only spray on and w@$# off in short order which works fine. I wouldn't soak parts in it. The use of petroleum distillates is prohibited in my state.
Last edited by Wildhorse Cafe on Mon Feb 11, 2019 12:37 pm, edited 1 time in total.
Post by rougaroo » Mon Feb 11, 2019 12:00 pm
Really like the pic of the case after Green Magic. Super results!
I looked it up, though, and have to throw in a caveat if you use it, or Simple Green or the like. Green Magic has a pH of 12.7, meaning it is a strong alkaline cleaner. It's probably ok to spray on/w@$# off quickly, but alkaline solutions can turn aluminum black if left on too long. You really should clean aluminum with acid cleaners, but there aren't that many around. I had a really crudded-up FD and left it soaking in Simple Green too long. When I sprayed it off, the FD looked like it was anodized, but with streaks. Not good.
darkhorse
Post by darkhorse » Thu Jul 11, 2019 7:59 pm
I recently used this on a number of items on my rig and it worked quite well on cleaning up areas that were covered in grease. I used it on the engine housing, gearbox, frame, and wheels.
A large can at Walmart is about $5.
2001 Ural Deco Classic
PowerArc Ignition
Mikuni VM28 Carburetors
Inertial Supercharger
Post by RC20 » Fri Jul 12, 2019 11:54 pm
I have not used the S100 engine cleaner but I have the S100 cleaner.
That stuff is wonderful. I plan on the engine cleaner since I saw it in their literature. I try to keep it all as reasonably clean as I can. Its going to age but like me (I quit my job did not retire) aging as gracefully as possible is important (some and some for me)
Like any petroleum solvent its also going to get on the ground. I am not a super tree huger but I try to keep it down as much as possible and with modern cleaners, you can do that.
I recently shifted my rifle cleaning to a non haz non odor cleaner and it works vastly better than any brute force cleaner out there, even the toxic ones. The new stuff is not just environmentally better, it works better. I even ran across some stuff that is as good as Tri Clorehtalane (yes spo) and I never thought I would see the day (and its a non hazardous stuff to boot)
Also, they don't evaporate completely so will work on rubber unless you use Simple green as an after fluhs (and why not just use that?). Theyu also attract dirt.
Post by VWK75S » Sat Jul 13, 2019 6:29 am
hotflash44 wrote:
Fri Feb 08, 2019 6:51 pm
try to get the factory new look on engine cases is really hard.
No it isn't, here's how I did it. :?
When reinstalling the gas tank forget to reconnect the cross over hose. :feelsgood:
You can get on gallon of the stuff for under $3 bucks. :)
2009 GearUp 145,000kms
glacoste
Post by glacoste » Sat Jul 13, 2019 8:07 am
I recently cleaned the my engine using citrus degreaser and a tooth brush. Plus I had a spray bottle with water to rinse off the cleaned areas.
2013 Gear-up
brookscooper
Post by brookscooper » Sat Jul 13, 2019 12:12 pm
Here's what I've done with other sandcast aluminum engine cases - clean as necessary. Clean the case with a mild solvent after the first cleaning, then use brillo pads and aluminum spray pain to "scrub" paint into the pores of the engine. Result is a case that's easy to clean as grease and dirt don't lodge in the pores. Did that to my Type 247 BMW engine years ago and it cleans up with nearly no effort, no matter how dirty these days. Hope that helps.
2004 Black / Chrome Tourist
Portland, OR
