Engine case cleaning
Cleaned worst off at car w@$#, sprayed with engine gunk and scrubbed, came out better, still looking to improve, brillo as pads maybe? Have been told easy off oven cleaner will turn cases grey, any suggestions? Don't have parts cleaner
Re: Engine case cleaning
good question try to get the factory new look on engine cases is really hard. youtube has several suggestions, i would like to know what the professional restorers do! maybe sand blast??
Don't know any easy/cheap/magic tricks. For grease/grime removal I scrape the big clumps out of the corners etc. I've used engine gunk and it helps for the oily/greasey stuff. The stained areas require old fashioned elbow grease and a stiff parts brush and solvent. Verisol(sp?) was a good parts washer but I mosty just used gasoline. Naptha is good but none of makes it look dealer showroom bright. To get cast alum case surfaces back to original brightness you can try Brillo pads but expect the rough cast surface will just shred them. Think...cleaning your concrete side walk steel wool.
If ya gotta have orig factory brightness, clean/degrease as best you can then explore soda or other media blasting.
- Tomcatfixer
- Commissar
- Comrade General
I can’t believe the amount of foul language in this thread
Jon
Nomad
2015 Ural Gear Up
Nomad
2015 Ural Gear Up
- snowymonkey
Subsnowden wrote: ↑Fri Feb 08, 2019 9:33 pmI can’t believe the amount of foul language in this thread
- Wildhorse Cafe
Ebay, buy some chemical spray bottles.
You just used a brush with green magic
- Bilgekeeldave
- Commissar
I like to let a nice patina of crud build up, I haven't cleaned my rig in years!
Dave
RAMCO-Dnepr MT-16
RAMCO-Dnepr MT-16
- Wildhorse Cafe
I sprayed it on full strength let it set a while then sprayed again to see where the really tough places were used a plastic bristle brush and repeated til I was happy and hosed it off.
2011 Patrol Higgs Bison Super Collider formally known as the Orange and Silver Pumpkin Coach.
2013 Black Retro, my name is nobody.
- Mr Wazzock
- Contact:
Wildhorse Cafe wrote: ↑Sat Feb 09, 2019 12:25 amEbay, buy some chemical spray bottles.
[green magic]
Can't get it over here unfortunately.
Yep, or aqua blasting. I know someone does this, parts come out like new. As with sand blasting have to be dismantled tho I think really, which is a right PITA if you just wanted to clean your engine, not have it to bits.hotflash44 wrote: ↑Fri Feb 08, 2019 6:51 pmgood question try to get the factory new look on engine cases is really hard. youtube has several suggestions, i would like to know what the professional restorers do! maybe sand blast??![]()
- Claus
- Contact:
No way to get green magic over here. That looks like one brilliant cleaner.
Easy-Off will work. Very powerful. Don't get any on your paint. If you ever get something melted onto you pipes or engine like plastic, easy-off is great. Works with heat obviously. Can be toxic.
That Green Magic product looks pretty incredible.
2006 Honda "Big Ruckus" PS250
hey guys word of caution, i have damaged polished aluminum with common cleaners, like permanent etching on the surface. some of this stuff if left to sit to long will eat aluminum.
- BlueRockCrawler
- Comrade General
Kerosene
2015 Ural Patrol
1993 Suzuki DR 650
2018 Suzuki DR 650
previous Honda's were
1996 750 Magna
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
1993 Suzuki DR 650
2018 Suzuki DR 650
1996 750 Magna
2004 919
1985 500 Magna
