Page 5 of 5
Re: drive shaft greasing made easy
Posted: Sun Feb 10, 2019 12:28 pm
by Snuggly Ranger
I am looking for one of the Tecalemit grease guns and I have found two versions. one looks like it has a tip and the other is like the one Windmill is using. Does anyone know if the one in this photo will fit into the drive shaft?
Thank you!
Posted: Sun Feb 10, 2019 12:32 pm
by windmill
Thank you!
I don't think the larger one pictured will fit.
Posted: Sun Feb 10, 2019 12:41 pm
by Snuggly Ranger
Ok thank you!
Posted: Sun Feb 10, 2019 1:24 pm
by Donbmw
Here is what I use
Posted: Sun Feb 10, 2019 4:36 pm
by hotflash44
just found out why IMZ hasent addressed the awkward angle of the FD joint zerk fitting,its said the u-joint is scheduled to be greased at the same time the FD drive shaft splines are serviced. so if thats done the zerk is easy to get to. makes sense i guess. :cheers: :idea:
Posted: Fri Feb 15, 2019 11:18 pm
by HassoBoxhead
Here is what I use
What is the model for that?
Posted: Sat Feb 16, 2019 6:05 pm
by MojaveSidecar
Just scored one like WIndmill's on ebay.... the shipping was more than the price of the gun.
Estimated delivery Monday, Mar 4, 2019 - Wednesday, Mar 6, 2019
MG AUSTIN HEALEY TECALEMIT GREASE GUN
Tecalemit GB2787.
Item price $15.42
Posted: Sat Feb 16, 2019 6:11 pm
by Mr Wazzock
Actually that makes perfect sense. So the zerk only means not having to take the UJ joint apart to regrease it. So it isn't meant to be accessible when shaft is installed. :D
I remember my dealer saying once that for the early shafts, there was no point regreasing the UJ because by the time it needed it the splines were worn out so the shaft needed replacing anyway. :D
Posted: Sat Feb 16, 2019 7:34 pm
by hotflash44
now that we are enlightened want to buy a bunch of grease gun nozzles/needles cheap? :boogie: :boogie:
Posted: Sat Feb 16, 2019 9:05 pm
by Donbmw
Here is what I use
It is just a compact grease gun with the Lincoln #5803 tip on it.
