drive shaft greasing made easy
Snuggly Ranger
Re: drive shaft greasing made easy
Post by Snuggly Ranger » Sun Feb 10, 2019 12:28 pm
I am looking for one of the Tecalemit grease guns and I have found two versions. one looks like it has a tip and the other is like the one Windmill is using. Does anyone know if the one in this photo will fit into the drive shaft?
Thank you!
2016 Gear Up
Post by windmill » Sun Feb 10, 2019 12:32 pm
Thank you!
I don't think the larger one pictured will fit.
Snuggly Ranger
Post by Snuggly Ranger » Sun Feb 10, 2019 12:41 pm
Ok thank you!
2016 Gear Up
Donbmw
Post by Donbmw » Sun Feb 10, 2019 1:24 pm
Here is what I use
Don
Post by hotflash44 » Sun Feb 10, 2019 4:36 pm
just found out why IMZ hasent addressed the awkward angle of the FD joint zerk fitting,its said the u-joint is scheduled to be greased at the same time the FD drive shaft splines are serviced. so if thats done the zerk is easy to get to. makes sense i guess. :cheers: :idea:
HassoBoxhead
Post by HassoBoxhead » Fri Feb 15, 2019 11:18 pm
Here is what I use
What is the model for that?
2014 Slate Grey Gear Up
MojaveSidecar
Post by MojaveSidecar » Sat Feb 16, 2019 6:05 pm
Just scored one like WIndmill's on ebay.... the shipping was more than the price of the gun.
Estimated delivery Monday, Mar 4, 2019 - Wednesday, Mar 6, 2019
MG AUSTIN HEALEY TECALEMIT GREASE GUN
Tecalemit GB2787.
Item price $15.42
Randy
06 GearUp Forest Camo
00 DRZ441 - E plated, Nova Wide Ratio Gear Set, Moto-Mule Trailer
01 DRZ400 - E green sticker
01 KLR/DMC Enduro Sidecar (in parts for a while longer)
11 GearUp Gobi (sold)
Looking for a Ural ST solo to add to the stable.
Post by Mr Wazzock » Sat Feb 16, 2019 6:11 pm
Actually that makes perfect sense. So the zerk only means not having to take the UJ joint apart to regrease it. So it isn't meant to be accessible when shaft is installed. :D
I remember my dealer saying once that for the early shafts, there was no point regreasing the UJ because by the time it needed it the splines were worn out so the shaft needed replacing anyway. :D
Post by hotflash44 » Sat Feb 16, 2019 7:34 pm
now that we are enlightened want to buy a bunch of grease gun nozzles/needles cheap? :boogie: :boogie:
Donbmw
Post by Donbmw » Sat Feb 16, 2019 9:05 pm
Here is what I use
It is just a compact grease gun with the Lincoln #5803 tip on it.
Don
