drive shaft greasing made easy
Post by windmill » Fri May 04, 2018 10:30 pm
I got a couple of mini vintage Tecalemit grease guns off e-bay for when I'm out in the field using my David Bradley walk behind tractor, or Planet jr wheel hoe, as a grease gun, and a wrench are the 2 tools one is most likely to need.
As a whim I decided to try them for my weekly greasing of my Urals drive shaft. The silver one is perfect for the job like it was made for it. Just reach over the seat one handed, place it on the zerk, press it down twice and done. All of 2 seconds to do, no 2 handed contortions, or trying to find just the right angle to fit it in place. ,
No bigger than a 5/8" wrench, so it can be carried in the tool kit for long trips.
Re: drive shaft greasing made easy
Post by VWK75S » Sat May 05, 2018 6:21 am
windmill wrote:I got a couple of mini vintage Tecalemit grease guns
That's 8) is the plunger in the needle end?
2009 GearUp 145,000kms
2007 Retro 20,000kms
Post by GHGoodwin » Sat May 05, 2018 6:40 am
Nice find. I have a somewhat similar small gun (2oz capacity) that has a thumb press. You hold it like a pistol. About the size of two of those set at right angles.
Post by windmill » Sat May 05, 2018 11:52 am
The entire body is the plunger on the silver one, the applicator sides into the body. The top cap of the brass one is the plunger, and the applicator is fixed.
The brass one was cheaper, and seem more common, but I recommend the silver one as it fits the zerk better, and has a more positive action.
Mikey
Post by Mikey » Sat May 05, 2018 12:03 pm
Barry, someone stole the middle of your tractor!
2017 Gear-up Forest fog
Post by windmill » Sat May 05, 2018 12:12 pm
Mikey wrote:Barry, someone stole the middle of your tractor!
I'm the "middle". :D
Safetybob3
Post by Safetybob3 » Sun May 06, 2018 8:23 am
Where does one find this?
Ural M70
Dnepr Mt 11
Dnepr Mt 9
Dnepr Mt 11
Dnepr K 750
Dnepr Solo
Ural Patrol
Ural Tourist
Post by GHGoodwin » Sun May 06, 2018 8:57 am
Safetybob3 wrote:Where does one find this?
Amazon. "Wolflube plunger style grease gun"
Safetybob3
Post by Safetybob3 » Sun May 06, 2018 5:51 pm
Thank You!! Just what I need!!!
SB#3
Ural M70
Dnepr Mt 11
Dnepr Mt 9
Dnepr Mt 11
Dnepr K 750
Dnepr Solo
Ural Patrol
Ural Tourist
Post by hotflash44 » Mon May 07, 2018 9:45 am
windmill wrote:I got a couple of mini vintage Tecalemit grease guns off e-bay for when I'm out in the field using my David Bradley walk behind tractor, or Planet jr wheel hoe, as a grease gun, and a wrench are the 2 tools one is most likely to need.
does the silver gun work easy on the patrol and m70. its a neat gun were there more on ebay?
Post by hotflash44 » Mon May 07, 2018 9:56 am
I just stumbled on to this very good link on the proper operation of the Tecalemit grease gun with pictures and advice. :cheers: http://ariel-square-four.blogspot.com/2 ... -guns.html
Post by windmill » Mon May 07, 2018 12:07 pm
hotflash44 wrote: does the silver gun work easy on the patrol and m70. its a neat gun were there more on ebay?
Yes it does, it works well on everything I've tried it on. Yes there's more on e-bay.
Post by hotflash44 » Mon May 07, 2018 12:15 pm
thanks i already have the various grease guns/needles but i like the compact design of your gun. i went to eBay pricey little buggers! :cheers:
Post by Lofty » Mon May 07, 2018 1:40 pm
windmill wrote:
hotflash44 wrote:Does the silver gun work easy on the patrol and m70?
It's a neat gun. Were there more on ebay?
There's one less. Mine arrived in the mail today. It's identical to the small silver one pictured in the first post of the thread.
I just have to figure out how to load it (it was shipped empty, as it should have been.)
The page that hotflash44 links to,
I just stumbled on to this very good link on the proper operation of the Tecalemit grease gun with pictures and advice. http://ariel-square-four.blogspot.com/2 ... -guns.html
illustrates the brass version of the grease gun, which has a different design and internal operation.
Post by windmill » Mon May 07, 2018 3:07 pm
Just unscrew the top, pull plunger until its all the way to the bottom, and pack it full of grease. I suppose one could also stick the open end in a full tub of grease, and pull on the plunger to suck it full of grease like a full size grease gun.
The plunger can be pushed straight out the top for cleaning, which might be a good Idea, mine had some old, hardened grease in it.
