Speedometer Issues Slowin' Me Down
jcbigears
Re: Speedometer Issues Slowin' Me Down
Post by jcbigears » Sat Jun 29, 2019 8:44 pm
Thanks Chad! Brilliant work!
2016 Ranger, left hand sidecar, underside of the equator
jcbigears
Post by jcbigears » Sat Jun 29, 2019 8:48 pm
Mon Jun 24, 2019 6:59 am
SO, it appears that they're both M18x1.5.
Hope this helps.
Thank you. Helps a lot. Now to find something to cover that thread over the transmission. I think that’s the same as sump plugs, isn’t it?
Post by Tomcatfixer » Sat Jun 29, 2019 9:04 pm
They're externally threaded. You need an internally threaded cap.
jcbigears
Post by jcbigears » Sun Jun 30, 2019 6:52 am
Not an easy item to locate down here!
Post by jaybird » Sun Jun 30, 2019 9:43 am
There are non threaded rubber or plastic caps that fit over that thread and seal the opening.
jcbigears
Post by jcbigears » Sun Jun 30, 2019 7:09 pm
"If something's worth doing, it's worth doing well" my father used to say.
Found it.
https://www.ebay.com.au/itm/282012623103
Post by jaybird » Sun Jun 30, 2019 10:04 pm
Found it.
That one appears to be 1" British Standard Pipe, is that compatible with M18x1.5 ?
While I had my speedometer cable off for replacement, I used something like this;
https://www.google.com/search?q=heater+ ... e&ie=UTF-8
jcbigears
Post by jcbigears » Sun Jun 30, 2019 11:09 pm
Correct. That's not the one I bought. My bad.
https://www.ebay.com.au/itm/362308409340
"If something's worth copying, it's worth copying correctly."
Post by Tomcatfixer » Mon Jul 01, 2019 7:24 am
:lol:
