Video - Ural Rear Wheel Removal
Post by Albuquralque » Mon Aug 05, 2013 9:59 pm
flying eyeball
Re: Video - Ural Rear Wheel Removal
Post by flying eyeball » Mon Aug 05, 2013 11:25 pm
now I know what that wrench is for :lol:
Thank you for another great video!
Josh
'05 Patrol
06motorradman
Post by 06motorradman » Mon Aug 05, 2013 11:44 pm
Thanks for doing that Darrell. If I swap my pusher and sidecar wheel to put the fresher tread at the pusher, is there anything I'll need to adjust or look out for?
My Bikes: 2011 Ural T ( gone on but not forgotten )
2006 BMW R1200RT, 2011 KTM 990 SMR, 2014 Vespa 300 GTS Super, 2016 Honda CRF250L, 2016 Honda CRF110
roger99a
Post by roger99a » Mon Aug 05, 2013 11:52 pm
And a good example of what can go wrong. I appreciate that!
Roger
2007 Patrol, the 'trol
Central California
roger99a
Post by roger99a » Mon Aug 05, 2013 11:54 pm
06motorradman wrote:Thanks for doing that Darrell. If I swap my pusher and sidecar wheel to put the fresher tread at the pusher, is there anything I'll need to adjust or look out for?
If you're like me your sidecar wheel won't come off.
Roger
Central California
SidecarDan
Post by SidecarDan » Tue Aug 06, 2013 2:15 am
Thanks for posting that Darrell. The last time I had my bike at the dealer and they took the back wheel off they forgot to put the bearing dust cover back on. When I went back to get it they handed it to me and said here you go, and made no offer to put it back on. Such is the service at my local dealer. :(
Dan
2012 Forest Fog Gear-Up
128/42 jets
7/64ths drilled slides
2013 branch pipes
Yamaha petcock
Post by Albuquralque » Tue Aug 06, 2013 9:56 am
One other thing I failed to show in the video is the washer that sits under the nut on the axle. It sits in a recess on the final drive. Most times the washer just stays in place, but sometimes it falls out. Make sure it is there before you put the nut back on the axle.
Post by Albuquralque » Tue Aug 06, 2013 10:12 am
You might need to make a fine adjustment of the rear brake linkage nut. Other than that it should be straight forward.
wildhair523
Post by wildhair523 » Tue Jul 02, 2019 7:30 am
I know this post is 6 years old - but where do i find the link to the video?
Born OK the First Time!
"Do not go wherever the path leads. Instead, go where there is no path and leave a trail " Emerson
2000 Yamaha RSV
2013 Ural T - "Trece Suerte" - Lucky 13
mattzahr
Post by mattzahr » Tue Jul 02, 2019 7:37 am
TCF to the rescue!!!
wildhair523
Post by wildhair523 » Tue Jul 02, 2019 9:28 am
The video link in several other "How-to" videos also does not seem to be there. Is it my computer settings or ........are the links elsewhere.........got removed.......?
2000 Yamaha RSV
Waffl6
Post by Waffl6 » Tue Jul 02, 2019 5:29 pm
I believe it's an error in the websites coding. There are two "youtube" link embed tags available, and the regular one has never worked for me. Using "youtube2" does work, however. I think these were using the regular youtube tag which no longer works.
The videos still exist offsite:
edit: By quoting the original post you can see that it does indeed use the regular youtube embed tag and not youtube2.
Probably the youngest guy in the room.
Current bikes: 1987 Rebel 250, 1990 Ninja 500, 2009 Honda Shadow 750, 2006 CBR600F4I, 2011 Ural Patrol T - A real POS
Past bikes: 1994 Katana 600
Fairfax Virginia
wildhair523
Post by wildhair523 » Tue Jul 02, 2019 7:37 pm
Thanks. And thanks for the tip on quoting the original post - the tag at least showed up there.
2000 Yamaha RSV
Post by Tomcatfixer » Thu Jul 04, 2019 9:24 pm
Had to outsource this time. :wink:
