CV Carb queston
George Butz
CV Carb queston
Post by George Butz » Fri Oct 26, 2012 11:00 am
The 07's carbs have always performed great after Gene re-jetted them. :)
I have torn down the rig and am checking the carbs out and cleaning the float bowls etc.
When opening the top cover the diaphragm seems misshapen and it is not going to seal around the lip of the casting I don't think.
Is it time to just replace them or is there a trick to getting them back in and sealing the lid? :?
Сьюзи (2007 homemade Gear-up)
(1988 BMW conversion)
http://www.easternbloc.biz
Re: CV Carb queston
Post by gobium » Fri Oct 26, 2012 11:08 am
Put in front fan, let it dry, will shrink back to shape
George Butz
Re: CV Carb queston
Post by George Butz » Fri Oct 26, 2012 11:14 am
gobium wrote:Put in front fan, let it dry, will shrink back to shape
I figured they had to be a trick. They show no sign of deterioration.
I will try that...Thanks
berger
Re: CV Carb queston
Post by berger » Fri Oct 26, 2012 12:07 pm
...or just let it sit overnight. It is saturated with gas.
Berger
2007 Ural Patrol (1st Owner)
Many, Many Mods.
Re: CV Carb queston
Post by GHGoodwin » Fri Oct 26, 2012 12:44 pm
Fill the groove with vaseline or grease. It'll hold the rim in so you can fasten the top.
George Butz
Re: CV Carb queston
Post by George Butz » Fri Oct 26, 2012 6:24 pm
Thank you all...They dried out and now go where they a supposed to.
And a little grease will keep it "in the groove"..... :D
RidesInRed
Re: CV Carb queston
Post by RidesInRed » Fri Oct 26, 2012 8:48 pm
That's that $#!+ gasohol. Real gasoline doesn't do that to rubber diaphragms.
2011 Orange Patrol Лилия Liliya (Lily)
Stock Jets, 2 shims
CIB, Purple Heart
Life member; Military Order of the Purple Heart
Jeff's first law of technology: Everything not tested doesn't work.
cdscoot
Re: CV Carb queston
Post by cdscoot » Fri Oct 26, 2012 9:47 pm
Gotta wait for the Viagara to wear off ! :lol: :lol: They shrink, get floppy , fall in place !
Craig
2010 Patrol T
2016 BMW R1200GS
n3303j
Re: CV Carb queston
Post by n3303j » Sat Oct 27, 2012 4:48 am
George Butz wrote:Thank you all...They dried out and now go where they a supposed to.
Don't know if grease is good for the rubber. A bit of care and they install fine dry. Matter of fact I've removed/replaced the diaphrams a few times and had no problem doing the reinstall within minutes. Just requires a gentle touch and a bit of attention. Gravity will do the rest.
threewheeler
Re: CV Carb queston
Post by threewheeler » Sat Oct 27, 2012 11:52 am
Hi guys,
Beware of using vaseline on rubber. My Dad worked for the London Rubber Company in the late 60s and I was curious about all the boxes of samples in the garage.
Yes, they made durex and his words of wisdom to me then ( when I was about 12!) is that vaseline causes rubber to deteriorate
I knew if I waited long enough that information would turn out to be useful!
All the best,
UK Based
2006 Ural Dalesman
2003 Kawasaki er500
1984 MZ TS 125
1989 MZ ETZ125
threewheeler
Re: CV Carb queston
Post by threewheeler » Sat Oct 27, 2012 11:53 am
Forgot to say. If you want to lubricate rubber parts on a motorcycle use plumbers silicon spray.
UK Based
2006 Ural Dalesman
2003 Kawasaki er500
1984 MZ TS 125
1989 MZ ETZ125
