Fuel Petcock Question
Post by Albuquralque » Tue Oct 09, 2012 7:47 pm
I went to pull my manual petcock to check/clean it. As I was trying to get the fuel line off of the petcock, the whole brass fitting piece came out of the petcock housing.
It doesn't appear that there was any type of adhesive holding this piece in there. It seems to just have been pressed in.
Thoughts on reinstalling it? Just press it back in as far as it will go? Should I use some type of adhesive? JB Weld?
Re: Fuel Petcock Question
Post by Albuquralque » Tue Oct 09, 2012 7:49 pm
Sent from my DROID3 using Tapatalk 2
berger
Post by berger » Tue Oct 09, 2012 8:19 pm
Yes, they are press fitted in.
Berger
2007 Ural Patrol (1st Owner)
Many, Many Mods.
George Butz
Post by George Butz » Tue Oct 09, 2012 8:23 pm
Some fuel proof sealer would not hurt. i would take a trip to a good auto parts store and check the Lock-tite products.
Сьюзи (2007 homemade Gear-up)
(1988 BMW conversion)
http://www.easternbloc.biz
cdscoot
Post by cdscoot » Tue Oct 09, 2012 9:14 pm
Just tap it in with the little bfh!
Craig
2010 Patrol T
2016 BMW R1200GS
Post by Albuquralque » Tue Oct 09, 2012 9:14 pm
cdscoot wrote:Just tap it in with the little bfh!
that's just what I did!
DanKearney
Post by DanKearney » Tue Oct 09, 2012 9:20 pm
Mine came out the same way yours did last month. I just pushed it back in with my fingers. Hasn't leaked yet. But I do have a replacement Yamaha manual petcock sitting on the shelf for this Winter's to-do list.
Cheers,
Dan K.
Post by Albuquralque » Tue Oct 09, 2012 9:29 pm
DanKearney wrote:Mine came out the same way yours did last month. I just pushed it back in with my fingers. Hasn't leaked yet. But I do have a replacement Yamaha manual petcock sitting on the shelf for this Winter's to-do list.
Cheers,
Dan K.
thanks Dan! BTW, this is one of the Yamaha manual petcocks.
zoober
Post by zoober » Tue Oct 09, 2012 10:53 pm
Just a little aside about the petcock. I also switched over to the Yamaha one. When I was futzing around trying to get the little plastic filter off to cut down the brass intake tube to the right height out popped the brass tube filter and all.. Heya!!!! went and got my oem petcock and yanked that brass tube and filter out
and stuck it into the the Yamaha one and saved the new one as a spare tube and filter.
Zoober 2009 green patrol
modtop airbox, fmf high mount, powerarc 40/140
kamloops bc
Zoober
2009 Green Ural Patrol 45 000 km Abused and used 4 seasons.
failed hall effect switch 2nd final drive, bent drive shaft drive shaft, clutch job, flywheel & 3rd clutch, broken pinion rebuilt final drive. Snapped carb diaphragm springs, new starter
modified mod top air-box mg0200 airfilter 40 137.5 jets 3 mm shims power arc ignition 2-1 fmf high mount muffler duro tires halogen head light polly heaters aluminum rims big A$$ road sofa seat
DanKearney
Post by DanKearney » Tue Oct 09, 2012 11:49 pm
Coluralado wrote:thanks Dan! BTW, this is one of the Yamaha manual petcocks.
So I guess we can now be sure that Russian quality is equal to Japanese quality!
Cheers,
Dan K.
hrpchr
Post by hrpchr » Wed Oct 10, 2012 7:02 am
The press fit brass fuel outlet fittings do come out easily. They can be pushed or tapped back into the recess, or better yet, they can be slightly deformed by squeezing or gentle application of a Small hammer to make them slightly oval. Making them very slightly oval, instead of round, provides a bit of springy tension to increase the friction of the fit. Clean the fitting and recess and tap it back in.
If you have access to some Loctite-603, it would be about the best for this application. It is a high-strength liquid compound for press fit applications and is the one that is “tolerant of oil and other contaminants” like you might find in a fuel system. Sure, there are probably other sealants as well.
Chris
2008 Black Patrol, 130/45 Jets, Drilled Slides, Punched Baffles
Lee Pape
Post by Lee Pape » Wed Oct 10, 2012 7:28 pm
Take a small ball bearing that is larger then the hole. Place the ball over the top of the hole and hit it with a hammer. This will push metal down into the top of the hole making it tighter. This also keeps the hole round where as squeezing the tube deforms it and causes a possible leak path. Green wicking Loc-tite is also fuel proof and can be used after the tube is reinserted into the pet cock.
