starting a thread on TIPS OF THE DAY!
Post by gobium » Thu Sep 29, 2011 11:09 pm
Ok , help me get this thread going, need tips and technical how to fix ural faster and better! There are lot of tips and tricks all over the forum, we need to put on one thread. Thank you in advance :D
markhas
Re: starting a thread on TIPS OF DAY!
Post by markhas » Thu Sep 29, 2011 11:16 pm
"They All Do That!" :foilhead:
markhas
AMA member
ABATE Wisconsin
Re: starting a thread on TIPS OF THE DAY!
Post by gobium » Thu Sep 29, 2011 11:23 pm
How to put inner tube valve stem in rim hole quickly without cursing. Get old cap, drill hole and tight a string, go fishing.
Post by gobium » Thu Sep 29, 2011 11:32 pm
markhas wrote:"They All Do That!" :foilhead:
I know they all do that, but you have to dig out the good ones.
Just want quick tips without having to ask a question :P
Post by gobium » Fri Sep 30, 2011 12:05 am
Railbender suggested:
Using drill press to hold down bit driver and turn chuck by hand, to remove stuborn carb Phillips screw is a great idea.
Post by gobium » Fri Sep 30, 2011 1:10 am
Want a smooth, less vibrate handle bar? Fill handle bar with lead shots. bbs, or even sand.
To top it off! install bar ends. :idea:
mgtibb
Post by mgtibb » Fri Sep 30, 2011 4:00 am
An old passenger peg from a honda motorcycle clamped to the engine guard with a u-bolt makes for a great highway peg. For the hack side, just cut a piece of magnetic heater duct cover and put it on the top of the hack nose. Rest your foot up there and no scratching the paint.
2010 Ural Red October
2010 Kawasaki Concours 14
Mud Pie
Post by Mud Pie » Fri Sep 30, 2011 7:25 am
To fill your final drive with oil without making a mess or fabbing up a tricky funnel, get some baby bottles. The ounces are clearly labeled on the outside. Simply cut off the end of the nipple and inverted into the FD fill hole. The clear bottle lets you see when the oil has drained, much better than guessing with ketchup/mustard squirt bottles (plus you don't have to measure your oil, pour into the ketchup bottle, then pour into the FD).
Baby bottles also come with protective caps, so it'll keep it clean for next use.
2005 Ural Gear Up with DP-28 replica
Patriot Guard Rider
"I don't drive a Ural to make great time, I drive a Ural to have a great time."
"There is no way to rule innocent men. The only power any government has is the power to crack down on criminals. Well, when there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws." - Ayn Rand "Atlas Shrugged"
Post by gobium » Fri Sep 30, 2011 8:12 am
A member, somebody suggested:
WD-40 or windex work great when trying to remove or install
tire on rim. :D
eeyore
Post by eeyore » Fri Sep 30, 2011 4:27 pm
bead tool, makes life easy and its portable
https://www.denniskirk.com/_.p28308.prd
2015 softail deluxe w/motorvation spyder “fattie”
2010 gear-up nato camo "Pasha" (gone but not forgotten)
2007 sportster 883 "blue beast"
Post by gobium » Fri Sep 30, 2011 5:10 pm
Want to get rust out of your old tank?
Cut a couple 8" sections of small chain (dog chain). Drop in tank, put cap on, put in little PB blaster, WD 40 or not. Wait till wife out of town, wrap tank in blankets, stuff it cloth dryer, stuff more blankets if needed so tank will not flop around. Set dryer on air only setting, turn it on for couple hrs. Remove chain with needle nose plier.
You will have a clean tank and wife gets new dryer.
For single guy w/o dryer use neighbor portable concrete/cement mixer.
For HD guy, strap tank to back seat of hog and drive around the neighborhood. :wink:
markhas
Post by markhas » Fri Sep 30, 2011 5:10 pm
To all posters that don't include pictures......A TIP FOR THE DAY
"NO PICTURE, IT DIDN'T HAPPEN!"
markhas
AMA member
ABATE Wisconsin
Post by gobium » Fri Sep 30, 2011 5:15 pm
markhas wrote:To all posters that don't include pictures......A TIP FOR THE DAY
How do u take picture inside gas tank?
Post by gobium » Fri Sep 30, 2011 5:20 pm
Tips are FREE. Take it any way you want. :clap:
eeyore
Post by eeyore » Fri Sep 30, 2011 5:32 pm
gobium wrote:Want to get rust out of your old tank?
Cut a couple 8" sections of small chain (dog chain). Drop in tank, put cap on, put in little PB blaster, WD 40 or not. Wait till wife out of town, wrap tank in blankets, stuff it cloth dryer, stuff more blankets if needed so tank will flop around. Set dryer on air only setting, turn it on for couple hrs. Remove chain with needle nose plier.
And I'm planing to let you help me with my carbs?????????
:lol:
