Please....Let Us Know Back!!!
Underhill
Location: Corozal Town, Corozal, Belize, Central America
Re: Please....Let Us Know Back!!!
Post by Underhill » Tue Apr 16, 2013 9:22 pm
Ben at NW Ural has been a big help to me a couple of times. Intermittent stalling problem -- Hall effect sensor -- Ben knew.
'08 Patrol Hansel
and other stuff I don't drive much.
I used to be Overkill but theorists broke into my me-mail and things have gotten all iffy now.
Never been tired, never been hungry never been lied to.
Bugrit--millenium hand and shrimp
Johann
Post by Johann » Wed Aug 13, 2014 6:38 pm
I'm currently working out an electrical problem which has me perplexed. When I solve it I will post!.
CraigE
Post by CraigE » Fri Nov 11, 2016 4:37 pm
I'm new to Urals and am no mechanic, I really do appreciate all the help and advice from the members on the site.
Least I can do is reply.
I'll even post if I do anything of use for others. Today I fitted a Givi a210 screen to the bike. So will post some close ups, may help someone.
Thanks All
Craig
Ural 2016 Tourist
BMW R1250GSA
DL650 V Strom
Honda Dominator NX650 Street Tracker
Whiskeychute
Headlight woes
Post by Whiskeychute » Tue May 02, 2017 8:16 pm
Many thanks to all of you that helped this 'ol timer stumble his way through the electrical problems.....Since fuel tank was off in order to check all
hidden wiring, decided to replace the 2 relays that are under fuel tank even though they seemingly checked out ok......Repaced both relays, GOT HEADLIGHT.........GREAT HELP HERE ON YOUR WEBSITE.
Post by tgtrotter » Sun Jul 16, 2017 9:54 pm
Erratic to no Voltage FIXED !! Thanks to Wildhorse Cafe. Only once back in 1995something have I ever had a completely shorted and sudden battery death. Usually for me batteries hang on a slooow and predictable near death and rejuvenation charge again again and again. Lesson learned maybe...I just couldn't believe the trouble it caused now. Read the post titled http://www.sovietsteeds.com/forums/view ... 72#p612372 :lurker: :lurker: :cheers: :boogie: :clap: off to show the kids at the AP store a Ural :foilhead:
Post by hotflash44 » Mon Jul 17, 2017 11:09 am
Agree, most batteries will tell you when they are going to go bad, thats when to buy a new one.IMHO :D
Post by tgtrotter » Mon Aug 14, 2017 5:45 pm
Alternating Turn signal FIXED
I looked for loose wires under nacelle from right neck side of frame best I could. Nothing
I checked grounds at each signal on bike only. Nothing
I disconnected wire harness to car. Signal still alternating
I pulled the thermal BUSS 550 flasher and noticed one spade, of the three loose like a childs tooth. Ventured out for a replacement :foilhead: . Wasn't easy to find a simple 3 prong medium duty auto flasher. Everyone had a heavy duty $18-$22 electronic flasher. Ended up with a CEC EF33BP for $9.99 plus tax from our local " Pilot :?: Travel Center".
Installed it. :clap:
I'm not sending a video but take my word the signals flash and don't alternate with the indicator. :thumbsup: Snakeoil
This was an overnight project cause a name brand store said they'd have the cheapie flasher in the next morning. When I returned they had the expensive one and of course that was all that was available on earth. I left. I had thought overnight that a three prong flasher is getting one signal (input) and sending the pulse two directions. Hence the signals and the indicator and one loose spade. IDK it works AND I have a semi usable spare for me or others.
Post by Mr Wazzock » Mon Aug 14, 2017 7:23 pm
3 prongs = supply, ground, and output. No 2 outputs.
I would expect...
Whiskeychute
Post by Whiskeychute » Sun Dec 09, 2018 8:25 pm
I sincerely hope I have not failed to respond to the "fixes" offered here by the experts. Being old & senile I sometime have an issue describing problem with my 2003 Ural G/U & am rather astonished when fixed, I may forget to respond...Had it about 4 years now & getting to trust 'er more....
Whiskeychute in Tennessee
2003 G/U
2001 H/D Fatboy with trike kit
2001 Kawasaki Drifter
1993 BMW K75S
codemonkey001
Post by codemonkey001 » Sun Dec 09, 2018 8:33 pm
Have to say this is a great post. I've only had one "what's wrong with my Ural" post, and made a point to come back, report the actual cause and solution, thank the person that pointed me in the right direction, and joined in the discussion of how to prevent it from happening again.
The wealth of knowledge available from the veterans on this forum is tremendously valuable.
2007 Patrol - Starbug
BloNo Illinois
