Resistor type plugs...
Desantnik-VDV
Re: Resistor type plugs...
Post by Desantnik-VDV » Sun Aug 22, 2021 12:04 am
It will cause radio frequency interference (RFI) - EMI (Noise). In a long run it can possibly cause damage to coil/magneto, electronic ignition or ECU due to no resistance.
Your engine can also run differently...
Alex
2007 camo GearUp - BMD (https://en.m.wikipedia.org/wiki/BMD-3)
40 idle/130 main/ 1.5 shim (0.8 mm washer)
The rest is just history... 4 previous Urals with telescopic front ends, BMW airheads, bigger Hondas, bigger sidecars...
Post by Wildhorse Cafe » Sun Aug 22, 2021 3:03 am
They won't be heard on your AM radio, what's an AM radio?
MonkeysUncle
Post by MonkeysUncle » Sun Aug 22, 2021 11:32 am
AM radios operate between midnight and noon.
2008 KLR650
2013 GearUp
Post by Mr Wazzock » Sun Aug 22, 2021 3:21 pm
:lol:
Yes only AM radios and old VHF TV's were mostly affected. UHF TV, FM and especially the modern digital stuff, cares not a jot. :D
If it helps, I changed my plug wires to straight copper and non-resistor caps, still resistor plugs tho, works fine, the 5k in the plugs is good enough.
Bigbikerrick
Post by Bigbikerrick » Fri Sep 24, 2021 7:04 pm
Nope, not IMHO. As long as they are the correct heat range. We have to remember, these are not really high tech machines. They are closer to a "ditch pump" motor! :P
Rick.
2012 Ural Gear Up / Forest Frog color. 2008 Goldwing Champion Trike, 73 Guzzi Eldorado, 17 Guzzi Griso
Canadian FJR
Post by Canadian FJR » Sat Sep 25, 2021 10:12 pm
I bought a set of BP7HS on Amazon.
Planning to buy another set to have as spares.
Canadian FJR
Ragmanxx
Post by Ragmanxx » Tue Sep 28, 2021 2:25 pm
I bought 4 BP7HS plugs from Amazon. I received 4 BPR7HS and returned them.
Found, hopefully, the correct plugs on Ebay.
https://www.ebay.com/itm/260926434474?V ... 0926434474
Ragman
"There's the way it ought to be..... and there's the way it is" (Sgt Barnes)
2011 Ural G/U Gobi Camo
Location - Glide,Oregon
CrankyTom
Post by CrankyTom » Wed Sep 29, 2021 7:23 am
I've been getting BP7HSC plugs at my local West Marine.They tell me the C only means that they are gapped at the factory.
I don't know what application they serve in boats,I go there because they still have the old style display rack - you can find your plugs without having a counter jockey look them up on a computer,which tends to be near impossible if your machine isn't in their data base.
Maybe other marine stores or marinas have them too.
I'm a Marxist at heart-you can't beat Groucho,Chico,and Harpo!
2012 Patrol T
aduthie
Post by aduthie » Wed Sep 29, 2021 9:09 am
They told you wrong about the C. A dash and a number at the end means they’re gapped at the factory:
https://www.ngk.com/ngk-spark-plug-numbering-systems
I have yet to find a motorcycle that runs differently with resistor-type spark plugs, so I saw no reason to horde non-resistor plugs when I saw NGK would stop making them. But the horders are out there if you want them, selling on eBay.
Andrew Duthie / Nashville Motorcycle Repair / Nashville, TN
Ragmanxx
Post by Ragmanxx » Sat Oct 02, 2021 6:50 pm
Seems opinions vary regarding Resistor Vs. Non-Resistor plugs.
I've always run non-resistor NGK BP7HS plugs with good results, but they are becoming harder to find.
For anyone looking, they can be had on FleaBay.
Ragman
