WTB Starter Jets for Keihin CVK32
Got some Russian bikes or parts you want to buy or sell? Advertise your wares here. Individuals only - No dealers in this section please.
This section is for individual forum members to buy, sell, or swap bikes, parts or accessories. Once the item has sold, please edit your post and put "SOLD" in the topic subject title. Dealers and other commercial entities need to post in "The Gray Market" section. All listings must be motorcycle related, preferrably for Urals or Dneprs. No guns, real estate, etc. All items must have an asking price or what you are willing to trade for. No auctions or bids here. If you want to auction an item, put it on eBay and post a link to your item's auction on eBay here.
Pete1163
Post by Pete1163 » Mon Mar 02, 2020 7:12 pm
As the subject states, I am in the market for new starter jets for my Keihin CVK32. When I disassembled my carburetors, I discovered one had a short 125 jet and the other had a 65 jet used for the starter jet. I have the correct main jets (130) and correct pilot jets (45) on both carburetors, so a jet didn't get switched around anywhere else. On another ural forum, I found a decent reference guide that shows a good schematic for the carburetor on page 122 (http://www.russianiron.com/eafranke_ural2/PartV.pdf) that lists the starter jet as the following: N42431065 Starter Jet 65. Unfortunately I have checked around with some dealers and haven't found a jet matching that nomenclature. If anyone can either point me in the write direction of where I can get this starter jet or has a couple of spares that they would like to part with, it would make my day.
Proud owner of a 2006 Ural Patrol as of June 2019.
Fairfax, VA
MChappy
Re: WTB Starter Jets for Keihin CVK32
Post by MChappy » Mon Mar 02, 2020 8:39 pm
Sudco.com or jetsrus.com are both good places to deal with.
07 Gear Up
Post by rivers » Mon Mar 02, 2020 8:58 pm
Unless seriously clogged up or physically deformed/buggered from a ham fisted owner, you shouldn't ever need to replace the orig 65 starter jets. They relate to the enrichers not the running of the bike. If yours are really fubar check with Terry Crawford. Don't know how common replacement starter jets are but I've bought a variety of pilot and main jets from Terry. He might also have starter jets? What year Ural you working on? I'm no carb guru but no stranger either and 130 mains and 45 pilots are IMHO pretty fat for a 750. What's your issue with your carbs. FWIW my 011 runs 123 mains with 2 shims and 40 pilots. Only reason I swapped from 38 to 40 pilots was for cold winter starting. Keep in mind when tuning/synching/balancing carbs the motor needs to be up to normal operating temp.
Pete1163
Post by Pete1163 » Mon Mar 02, 2020 9:10 pm
I sent an email to Terry, just haven't heard back from him. And technically I only need one 65 to replace the 125 that was in the starter jet spot. I have a Ural 2006 patrol 750cc.
Fairfax, VA
Eric N
Post by Eric N » Mon Mar 02, 2020 9:53 pm
Your main jets are a 99101-393
If you notice, the main and pilot have the same threads. People tend to swap them out in error, the prior owner of your bike probably tried cleaning the carbs, confused the jets, and your 65 is either in a random parts bin or trash.
I was never able to locate the technically correct jet when I ran into an issue back in 2016, but if you want a size 65 that will fit:
https://jetsrus.com/a_jets_by_carbureto ... 28-xxx.htm
The pilot only works with the enricheners on, only impacts cold starts, I think you can get away with putting a 99101-393-065 in both sides and call it good.
2013 Retro Solo
2001 Patrol - Sold
Post by jeffsaline » Mon Mar 02, 2020 11:35 pm
I too have had excellent results when buying carb parts from Jets R Us. Shipping as I recall is kind of expensive but last time I ordered from them I bought parts on Wednesday evening and they were in my mailbox on Saturday.
Too help make the shipping costs a bit easier to accept... maybe also buy two needles for the float system. As I recall they are about $45 from Kawasaki, $27 from aftermarket and from Jets R Us they were $7 for aftermarket and $10 for OEM. I used OEM as I think they are the best bang for the buck.
Post by jaybird » Tue Mar 03, 2020 6:42 am
My local independent motorcycle shop has quite a selection of jets and carburetor parts , you may have a shop nearby as well.
Post by Msblu79 » Tue Mar 03, 2020 8:31 am
The smaller size jets will work as well in a pinch. I actually run a set of 55's I found in a collection of carb bits from a garage sale of all places. I have never seen them anywhere else. It provides just enough extra fuel for a slightly higher idle without blubbering & wasting fuel, the 65's were to big for my setup. I get a nice clean high idle around 1500rpm on the enricheners, just right for a cold motor start. :)
2010 Black Patrol 92,000km's
Pete1163
Post by Pete1163 » Tue Mar 03, 2020 10:03 am
Thanks for the recommendations! Terry Crawford emailed me back this morning and has some in stock :D
Fairfax, VA
txparts
Post by txparts » Thu Apr 09, 2020 7:55 pm
Going forward go to JetsRUs they have large selection and good prices
1998 Ural Sportsman
1998 Harley Road King
1968 BSA Lightning
lsiemasko
Post by lsiemasko » Sat May 23, 2020 9:23 pm
JetsRUs and go to the Harley section. Same jets. Can buy OEM or aftermarket to save a few pennies. Been buying them there for years.
Larry S.
03 Tourist for me and the wife - Wehrmacht Style
02 Bavarian Classic (Custom Tub) for Walter,Peyton, Ellie May, Loki, and Jett, my mastiff monkeys!
03 Dyna Glide (Surface dust created by excessive use of the Urals)
03 Sportster 1200C - Wife's Ride (Unfortunately NO trunk for "stuff")
