750 Service Videos found on YouTube...
- JohnBG
- General Secretary
- Contact:
I found the Ural 750 service videos on YouTube:
John Grocke aka "JohnBG"
'06 Ural Raven - "Vorona"
'09 Kawasaki KLR650 - "Madea"
History:
2002 Harley Road King FLHPI
1980 Suzuki RM125T
1970 Honda CL100
“Love is the feeling you get when you like something as much as your motorcycle.” ― Hunter S. Thompson
History:
1980 Suzuki RM125T
1970 Honda CL100
- JPanyon
- Comrade General
head bolt torque..........
very nice collection of videos, BUT, there's no way in hades I'm going to try tightening those head bolts to 45 ft. lbs torque. My personal experience indicates that 28-35 ft. lbs is way more realistic, unless I've heli-coiled the threads in the engine case.
Factory fresh studs have more "stretchability" than older studs that have been "thermal cycled" several hundred times. So, new studs can use the higher inintial torque figures, while they heat cycle themselves to a final length and hardness.
Used studs will measure as slightly longer than fresh studs, and definitely have less "stretchability" in them. I play it safe and give myself a hefty margin when tightening used steel studs into aluminum base material.
So, I would treat the 45 ft-lb figure as a maximum to be used on fresh studs ONLY, with all new gaskets.
With used studs, and non-fresh gaskets, I'd use 35 ft.lbs
MAX torque, WET, meaning all thread material is lubricated while tightening.
Best Wishes to All
John Panyon
Best Wishes to All
John Panyon
750 Service Videos download links
Bearing_inspection.flv
http://www.ccab.co.za/templates/Custom/ ... ection.flv
Tire_inspection.flv
Steering_bearings.flv
http://www.ccab.co.za/templates/Custom/ ... arings.flv
Spoke_tensioning.flv
http://www.ccab.co.za/templates/Custom/ ... ioning.flv[/url]
Show in folderRemove from list
Spline_lubrication.flv
http://www.ccab.co.za/templates/Custom/ ... cation.flv[/url]
SparkPlug_inspection.flv
Sidecar_alignment.flv
http://www.ccab.co.za/templates/Custom/ ... gnment.flv
Oil_change.flv
http://www.ccab.co.za/templates/Custom/ ... change.flv
Fuel_filter_inspection.flv
Fork_oil_change.flv
Clutch_cable_adjustment.flv
http://www.ccab.co.za/templates/Custom/ ... stment.flv[/url]
Carb_balance.flv
http://www.ccab.co.za/templates/Custom/ ... alance.flv
Linkage_lubrication.flv
Brake_inspection.flv
Air_filter_service.flv
http://www.ccab.co.za/templates/Custom/ ... ervice.flv
Torque_headbolts.flv
http://www.ccab.co.za/templates/Custom/ ... dbolts.flv
Valve_tappet_adjustment.flv
Tire_inspection.flv
Oil_change.flv
Fork_oil_change.flv
Carb_balance.flv
2008 Gear Up
(seems to be 2007 spec though...)
I love Linex
I love Linex
- Comrade Colonel
Re: 750 Service Videos found on YouTube...
Oh.. my god. The music on the oil change video. It is amazing. I kept waiting for the dancing chicks to roll in. Great vids!
-RMRR
2007 Patrol in fancy black.
Solo Bike: DL1000 in filthy black.
Давай детка, будь моей обезьянкой
- Darkblood
- Order of Suvarov
- Location: Smithfield, Maine, now further into (Americas Siberia)
- LawtonLily
- Comrade Colonel
I have the videos on digits. PM if you want a copy on disc. Please keep in mind that I am moving and will do this as time is available.
Little Mike
08 Patrol
00 FLSTF
06 DVX90 ATV
08 Patrol
00 FLSTF
06 DVX90 ATV
- LawtonLily
- Comrade Colonel
UUUUGGGGHHHH, movers broke my CD with the videos on it! Hopefully they will replace them. I will get back with an update on it.
Little Mike
08 Patrol
00 FLSTF
06 DVX90 ATV
08 Patrol
00 FLSTF
06 DVX90 ATV
Very nice!
Special Ed
Tucson, Arizona
2006 Ural Patrol
синий ведро = Dark Blue Bucket
Honor God in all things
Tucson, Arizona
2006 Ural Patrol
- Comrade
Thanks JohnBG
- Knotlinks
- Party Member
Thank you!
Dave Coder
Western New York, USA
2012 Patrol T, Olive Drab
Good collection of videos!
Lily, did you ever get your CD's replaced? Would love to have a copy of these.
Thanks!
Thanks!
Gear head for over 40 years now. Have a BMW R1100RSL to ride right now, with several R75/5's waiting in line for restoration. New owner (Sept 2013) of a 2004 Ural Tourist that needs some TLC but in VG condition. Various cars (German and Brit) and a 2002 Dodge Cummins pickup. Please do not ask about antique airplanes or Ham Radios!
- Revtech100
- Comrade Colonel
- Contact:
Wellllll........after looking at the battery service, when I have to do that, I'm replacing it with an oddessy. Holy $#!+!
2003 HD Ultra Classic - Sold
1969 Honda Trail 90 - Sold
2011 BMW R1200GS Triple Black - gave away
2000 custom softball - gave away
2011 KLR 650 -Sold
2013 Ural Gear Up
2011 KLR 650 -Sold
2013 Ural Gear Up
- Albuquralque
- Order of Victory
On your 2013 model, you have the bolt on seat plate. Take the four bolts out and easy access to the battery!
- Kayaken John
- Party Member
oddessy batteries are good batteries or I should say I have had real good luck with the one I have in my 650 KLR since 2009 and it is still running strong. The video are very helpful, thank you for posting them.
Motorcycles owned, 2012 Ural Yamal LE, 1999 KLR 650, 1971 TS185 Suzuki (2)
If anyone has working links of these vids, it would be awesome. I am currently trying to troubleshoot a leaking final drive and hoping for the best.
My mechanical skills are at Curious George level...
I am riding a 2015 Ural Gear-up, winter camo, which is fitting here in Anchorage, AK.
