Possibly Helpful Stuff
Old Info From R.I.M.C. Posts
...Was sadly lost in a purge by the new owners .
As I tinker on my old bike ('94 650 Tourist) I'll post up part #'s .
I know the intake hoses for left & right are different P/N's , I'll be needing a new left side one soon and I seem to have lost the Goodyear P/N from last time .
'10 Solo sT Crashed & Ruined 6.26.17
MORE P/N's
O.K. lessee :
headlight is # 6012 or 6014 , tis is the std. two headlamp one , # 6014 is slightly brighter , made for trucks .
The driveshaft U-Joint application is 1979 MGB or MG Midget , they both use this extremely common joint .
I'm about to install a 2002 Retro front end to my old '92 Tourist so I'll soon know if the #31412 bearings are indeed , the same roller bearings needed for a Ural ~ they're supposed to be the same as BMW /2 .
- New Member
u joint
my carquest says all their u-joints start with a 2 in the part # but the guy said that there is a 1-0300....so I'll check and see if it matches my old one...needless to say I'll be using the h@#$ out of that sticky posting. Shanxs. Jeremy
chopping
- Party Member
Thanks a whole heck of alot
Just wanted to also say thanks for such a comprehensive list of Ural repair items. I have a 2004 Patrol and sooner or later will need to have this info. Thanks again.
Ernie Wade
El Paso, Texas
2004 Patrol
Ernie Wade
El Paso, Texas
2004 Patrol
2004 Patrol
Add wiring diagrams?
This is a great thread... one thing it could use, are links to those images/pdfs of the full-color wiring schematics. Any chance you could do that up? I just spent some time trying to search them up, but couldn't dig them up.
Cheers,
Anthony
2007 Ural Patrol - "Svetlana"
Antsaint - Food, the Web, Writing & Eugene, Oregon
http://www.antsaint.com/
Anthony
Ural schematic link:
http://www.thisoldtractor.com/guzzi007/Ural.html
Cannot comment on accuracy
OHV Dnepr (this one is best, shows mechanical and solid state relay):
- New Member
- Contact:
Replacing Ural Gas Cap
I know the Stant 10817 Gas Cap has been mentioned in several threads. In this day and age of Uber expensive gas you can replace your Ural Gas cap with the locking version: Stant 10591. If your looking for a cross reference it's a 1982 Ford Granada Regular Threaded Fuel Cap.
Konrad
Konrad
VWNate1 wrote:
The NAPA # 111X U-joint replaces the Spicer # 5-111X U-joint .
I hope this helps .
It does help -- very much. Thank you. I have updated the list.
Quote:
If you poke through my posts over on the R.I. Boards , you'll find the odd part #'s and brands of jobs I did on my Ural .
Many parts differ between 650 and 750 Urals too .
I never was able to get into the RI boards, so if you could re-post here, I daresay you would make lots of people grateful (I can call one by name! )
_________________
Fat Mack
Private, 1st Bn. Co. C, SCV Mechanized Cavalry
Riding Rosinante
Dreaming the Impossible Dream since 25 June 1953
I'll second that!
I hope this helps .
_________________
Fat Mack
Riding Rosinante
I'll second that!
JD
2006 URAL Patrol
1968 HONDA CL 350
Right is right, even if everyone is against it;
and wrong is wrong, even if everyone is for it. - William Penn
2006 URAL Patrol
1968 HONDA CL 350
- acegammer5
- New Member
- Contact:
Air box hose
Man this is a great list, but I would recommend using the following hose between the air box and carbs.
It is a John Deere piece of flex hosing that will run you about $12 after tax. It is super easy to put on works/looks great on my '99 patrol.
The great thing about it is that the ARE flexible and you and hit them and bump them all day without having to worry about knocking them off.
(After my fifth time of having to put my old ones back on to stop leaks I began looking around for something better. That and I came back home one night after work to find, what I assume, was the work of a drunk guy who climbed on my bike and completely knocked the left boot off.)
Don't have the part number right now, but I'll post it soon so you can find it for yourselves. If you want it now, go to a John Deere with a parts dept. and show them your current boot and ask if they have some flex tubing that would fit it. They should carry it in stock.
- Order of Lenin
parts list
Super post, thanks!
2010 Patrol T "Drab Olive" with upgrades
07 Triumph T100
05 BMW 1200 GS
ищите правду, Вы найдете это там
07 Triumph T100
05 BMW 1200 GS
- a1930ford
- Order of Victory
Re: Air box hose
