Shimming Final Drive Yoke
Post by Albuquralque » Sat May 18, 2019 8:19 am
Re: Shimming Final Drive Yoke
Post by gobium » Sat May 18, 2019 12:38 pm
I have 1wd fd. Will that works?
What happens if the draw bolt too loose?
Why is fd black and your engine is silver?
What up with the other drive shaft is the back ground?
Post by Albuquralque » Sat May 18, 2019 1:00 pm
All questions that will be addressed in due time...... :D
Post by Albuquralque » Sat May 18, 2019 1:11 pm
Yes same procedure for both 1wd and 2wd final drive
Post by Albuquralque » Sat May 18, 2019 1:13 pm
You will have to add more shims until you can just draw the wedge bolt to where the top of it is near flush with the yoke.
(Explained in video)
Post by BinDerSmokDat » Wed May 29, 2019 10:30 am
Very informative. I usually just re-install the shims when i rebuild.
The fit is always close, no detectable slop in the wedge pin but then again, I might not have been looking. :oops:
I will check next time I have the yoke off and shim accordingly.
